Bleed Valve
Bleed Valves, are they any good, do you keep the amal valve as it is and just put it in the line from amal to actuator? CheeRS pete
an amal valve is just an electric bleed valve mate!3 take offs,one goes to atmosphere thatll be the metering head one.mine has one fitted in line from the actuator,leaving the amal valve there at the mo!
comp housing goes one end of bleed valve
actuator hose the other
then wind it out to increase boost!
