engine warning light is on....
Old Apr 11, 2004 | 10:56 AM
DannyC's Avatar
DannyC
Default engine warning light is on....
Alright lads, I've recently changed my brakes to ST170 jobies, and at the same time removed the shitty ABS. After removing the ABS the orage brake light was on so i've removed the bulb like you do but the red engine warning light has also come on. When my mate John Laverick did the same job that light never came on, has anyone got any ideas as to what it might be? I've checked the brake fluid level and thats all ok, and i dout its to do with the handbrake cos it happened at the asme time i messed with my brakes.
Any help will be much appreicated
CheeRS
Old Apr 11, 2004 | 01:45 PM
Exeter J's Avatar
Exeter J
Thought the red (handbrake) light was tied in with the yellow abs one anyway.
When you removed the abs you should have unplugged the the abs sensors - most probably at the yellow connector. You need to bridge the two pins within the end of the yellow connector on the end of the loom as keeping contact between these keeps the abs light out.
If you mean the oil presure light - then it is possible you have pulled the connector from the sensor on the back of the engine when removing the abs.
Old Apr 11, 2004 | 04:28 PM
I recently got my Escort RST... its my 1st RS n my ABS wrks really well.... but all i hear is every1 slatein it off.... is mine a rarity to have the ABS wrkin or am i thinkin highly of sumthin that is no gd?
Old Apr 15, 2004 | 06:48 PM
S2martin's Avatar
S2martin
Ex Full Price gold member
To be honest my ABS on my old S2 was great i was all ready to take it off and i was visiting my mums in dorset giving it some beans on the country lanes 100+mph when a fuckin fox tried it's luck and the ABS got me right out of trouble never even attempted to lock up plus i had new discs pads and T1-Proxies
Old Apr 19, 2004 | 08:56 PM
Rick's Avatar
Rick
Properly setup ABS works very well.
Old Apr 20, 2004 | 07:34 PM
Yea mine does..... i did a litle test myself... i was doin bout 50mph then just wacked it down... the car nearly ripped my sline out... stopped sp quick,, with no pullin either side and only made the slitest of screeches rite as it stoipped... latsed bout an inch!
i was impressed as evry1 told me to take it off!
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
dojj
15
Aug 18, 2015 08:21 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Neatrags
Aug 16, 2015 07:57 PM
