Just finished fitting launch control and flat shift!! VIDEO
#41
Its a little nicer to the clutch too, instead of a 6500k revlimit then slip the clutch back down to what ever rpm you had before, and i guess its a tiny bit kinder to your syncros and they are matching a smaller rpm differential.
I love flat shifts, my car shudders at the very thought lol
Rob,
Rob,
#42
how much would i be looking at to set my car up with ms, at the moment its on ofac to get it up and running but im after some decent power and will need it mapping to what i have so im thinking of getting it done sooner, iv seen the kits and could fit it in its the mapping i cant do, is there anyone in manchester area that knows what there doing, also the car has no front running gear so will need someone mobile
cheers
cheers
#52
You won't be able to make full use of launch control and flat shift with the EDIS matey, if i remember correctly you can't spark cut with edis.
You would need some coil drivers, internal or external (i slightly favour external) and drive the ignition coil directly.
Rob,
Rob,
#53
ah yes think your right! been a while since I've played with it to be honest. well if I need a ms2 board putting in may as well put the coil driver in too. reckon it'll cost much?
#56
Thanks! Yes you can add it afterwards it's very easy, all the info can be found here http://www.msextra.com/doc/ms2extra/...are.htm#launch
JoeyBoyden
04-01-2024 02:36 PM
155lee
14-09-2015 07:37 PM
