MS vs Cossie Management
Old 19-06-2011, 11:31 PM
  #201
DazC
DazC's Avatar
I've made some changes to the start tables. I'm on my netbook with no e-mail so I'll get it transferred and e-mailed across tomorrow.
Old 19-06-2011, 11:55 PM
  #202
svony
svony's Avatar
Ok thanks...
I tried a couple of serial/usb convertors but after several tries I gave up and repaired my old Dell... will have to look into that adapter as I'm already getting tired of this 2 hour limit, not to mention I can keep it in the glovebox.
This map is full of surprises isn't it...? what's the difference between "fuel as injector" and "fuel as pwm" in the fuel injector setup of the map?
Old 19-06-2011, 11:56 PM
  #203
svony
svony's Avatar
While you do that I'll figure out what the injector specs are...
Old 21-06-2011, 09:42 AM
  #204
Rob_DOHC
Rob_DOHC's Avatar
Originally Posted by project rs
yes cars all good just getting a few of the extras like launch control, flat shift and nos control all added to it so when i get it back from rick can get them on car and see how it likes them should be interesting and the house will be up to scratch in another 6 weeks so going to start on a massive garage for my car and all the bits i've got spread round friends houses
Ahh good stuff mate, good luck with the house
Just fitted launch and flat shift to mine (although its off the road again so i havent played yet )
Rob,
Old 21-06-2011, 11:52 AM
  #205
Rogeyboy
Rogeyboy's Avatar
Be interesting to know how the flat shift works out Rob and the launch i guess altho i rarely launch mine that hard - useful nonetheless for showing up the local "youths" i guess lol!
Old 21-06-2011, 09:55 PM
  #206
Karlos G
Balls Deep!
Karlos G's Avatar
Rob,
Hmmm..... Flat shift... Something I think I should fit too!!
Rob how easy is it to add this to my V3.0 board, what do I need? (no probs with soldering the components in etc).
Old 24-06-2011, 01:30 PM
  #207
Rob_DOHC
Rob_DOHC's Avatar
Hello mate,
Pretty easy to add as long as you have a spare input. If your up for doing it i'll send you some pics ect. You really need a clutch switch too tho.
A resistor and a transistor and your away, ive got part number if you need those too.
Rob,
Old 24-06-2011, 01:32 PM
  #208
Rob_DOHC
Rob_DOHC's Avatar
Yea im looking forward to testing it when im back home the launch is on all the time (activated by the clutch switch) so its as simple as planting your foot on the clutch and giving it WOT, then dump the clutch.
Have a look on youtube for megasquirt launch control some good vids there.
Im considering having two switchs for mine (one clutch, one steering wheel) so i can limit wheel spin etc.
Rob,
Old 24-06-2011, 01:53 PM
  #209
Stu @ M Developments
PassionFords Creator
PassionFord Gold Member (Male)
Official PassionFord Trader
Administrator
Stu @ M Developments's Avatar
How are you guys programming your flatshift to give the power drop?
Old 25-06-2011, 10:00 AM
  #210
Rick
Rick's Avatar
Combination of ignition retard and dwell reduction as a "soft" limit, spark and or fuel cut can be used as a hard limit if needed. Spark cut is programmed to cut x out of y sparks, so you can vary how aggressive it depending on application.
Rick
Old 02-07-2011, 11:04 PM
  #211
Rob_DOHC
Rob_DOHC's Avatar
Came across this megasquirt launch control and flat shift vid the other day, can't wait until im all run in!
http://www.youtube.com/watch?v=dHuUfSPbhko
Old 03-07-2011, 09:09 AM
  #212
crazycage
crazycage's Avatar
mtx75 gearboxes dont like flat shift .
Old 03-07-2011, 10:46 AM
  #213
Rob_DOHC
Rob_DOHC's Avatar
Really? I've never given it a go in an MTX but a normal MT75 flat shift perfectly, although 3rd syncro always seems a little weak.
IB5's flat shift well. (a few times before the chocolate melts any way).
Rob,
Old 03-07-2011, 05:27 PM
  #214
Karlos G
Balls Deep!
Karlos G's Avatar
Rob,
Old 03-07-2011, 05:37 PM
  #215
Rob_DOHC
Rob_DOHC's Avatar
Lol, you know its true. Didn't you know all IB5's had a chocko gear? i hear the bc's have got more than one!
Old 03-07-2011, 05:48 PM
  #216
Karlos G
Balls Deep!
Karlos G's Avatar
So far mine has lasted with no probs, so I'm going to touch wood and hope it does ok with my new turbo too! Killed 4 BC's though! lol
mk3ste
17-10-2021 10:09 AM
gcfcos
59
06-10-2015 05:04 PM
griffo69
04-10-2015 11:58 AM
XR4
Ford XR Range
01-10-2015 12:46 PM
deathrider666
28-09-2015 06:12 PM
Quick Reply: MS vs Cossie Management
