Engine Rebuild time :(
Old Apr 24, 2011 | 10:39 PM
Joe91's Avatar
Joe91
Default Engine Rebuild time :(
Put my new turbo on last night and finally got the car running today, been driving it all day and having fun.
Basically it comes on full boost at 5k revs, and goes like f*ck..I was just driving home and i was playing with some mates on the dual carrige way when my car topped out at 110..Anyway i carried on driving home and it sounded like it was missing, so i pulled over in the petrol station, opened the bonnet only to find my dipstick was out and oil had pissed everywhere!! So i think ive dropped a ring or even f*cked a piston? Any ideas?
It doesnt sound good, my mates said its time for a rebuild, but im not exactly the richest boy in the world to say the least!!
Roughly how much for a rebuild?
Any help is appriciated..Joe.
Old Apr 24, 2011 | 10:43 PM
liam-rst's Avatar
liam-rst
shit happens
mate u cant even begin to factor a cost in until u kno the extent of the damage but no am afraid its not good
Old Apr 24, 2011 | 10:56 PM
bubs_rsturbo's Avatar
bubs_rsturbo
sorry to hear that mate
Old Apr 24, 2011 | 11:19 PM
Jimmyc's Avatar
Jimmyc
As said above, doesn't look good.
The cheapest and easiest option would be to buy a good known bottom end or full engine.
But if you want to rebuild it, DIY as liam said can vary depending on machining needed.
As a rough guesstimate, my build with arp rod bolts and crank & flywheel grind and skim probably cost between about Ł400 and Ł500. That's just a quick sum if all the main parts off the top of my head.
Hope you get it sorted though bud...and get it set up properly after too! Lol
Old Apr 24, 2011 | 11:29 PM
Joe91's Avatar
Joe91
Yeah its a pain, it was booked in on may 6th to have Omex 600 put on aswell!! Such a waste, dont know wether to buy a new engine or rebuild mine, its dodgy buying a new engine because you dont actually know if what its described as is true..
Old Apr 24, 2011 | 11:36 PM
Jimmyc's Avatar
Jimmyc
Ah gutted!
It is a bit of a gamble I know what you mean, that's why I rebuilt mine atleast I know its in a good state now.
Old Apr 25, 2011 | 08:56 AM
liam-rst's Avatar
liam-rst
shit happens
what jimmy says sounds about the right price for a normal build mate, also what i would say is take off your head and inspect the bores first as if one is fucked or the bores are lipped too much u will need a rebore an poss new pistons, which will be a huge lump of money an maybe best just to buy a good bottom end as jimmy says, i only originally took my engine apart for a bit of a freshen up as it was slightly low on compression on bores 2/3 and have ended up replacing pretty much everything, the only things still left from when i started is the crank and rods, i guesstimate that its cost me around 1k to build myself as i said u need to kno the extent of the damage 1st, if i can help in any way just send us a pm im always on here
Old Apr 25, 2011 | 12:23 PM
Pridzz's Avatar
Pridzz
So gutted - Escort was going like fuck aswell!
It would be so much cheaper if we knew what we were doing. But seeing as your guna have to pay somone to do the labour thats when it starts get pricey!
Loan = Forged internals and do it proply!
Old Apr 25, 2011 | 06:40 PM
liam-rst's Avatar
liam-rst
shit happens
if he really cant afford to pay to have the work done send the engine and parts to repair it to me and ill do the work foc, all he will need to pay for is any machining needing doin or he could get all this done himself and send me the parts and ill build it up for him, may work out cheaper sendin it to me than payin for labour,
thanx
liam
Old Apr 26, 2011 | 09:41 PM
Joe91's Avatar
Joe91
I have some good news and that is the car started earlier and sat there idling for 20mins then i drove it around the block, so its not the pistons thankgod! There wasnt any smoke etc or signs of it. It still sounds like its slightly misfiring though, its hard to tell as ive just put a .63 rear housing turbo on it so the exhaust note has changed alot since it took place.
Ive heard that the breather pipes can block and cause this aswell? I still have a standard breather system on it :/ Should get a baileys really!
Thanks for the off Liam and thanks for all the help lads.
Joe.
Old Apr 26, 2011 | 10:00 PM
Jimmyc's Avatar
Jimmyc
Joe.
Nice one, just dont let it come on boost until youve had the fuelling checked or you'll be back on here asking for more help rebuilding it! Haha
Old Apr 26, 2011 | 10:04 PM
luke19790_3's Avatar
luke19790_3
did you have it setup after changing the turbo?
Old Apr 27, 2011 | 02:24 PM
Joe91's Avatar
Joe91
No I didn't, it's going in next week to have omex fitted!! :P so it will all be done then. And it will be a nice realible, first time starter!
Old Apr 27, 2011 | 06:39 PM
luke19790_3
you didn't drive it after fitting the turbo did you? not a good idea if you have mfi
Old Apr 27, 2011 | 08:29 PM
Joe91's Avatar
Joe91
Yeah i did unfortunatley, i was to excited to drive it! i still need to drive it but i just wont go on boost till its been setup!
Old Apr 27, 2011 | 08:43 PM
luke19790_3
poor pistons
Old Apr 27, 2011 | 09:24 PM
Rob_DOHC's Avatar
Rob_DOHC
thanx
liam
All I can say is top bloke.
I would agree with every thing above tbh. You just wont know anything until its out the car, stripped and clean.
You may be lucky and just have a burned exhaust valve for instance, or you could have a damaged piston etc, you just don't know.
A compression test will tell you lots / point you in the right direction.
Good luck
Rob,
Old Apr 27, 2011 | 09:26 PM
Rob_DOHC's Avatar
Rob_DOHC
Shit, just read the rest of the thread lol,
Sounds promising!
Don't forget the the missfire could have (would have!) been caused by the dipstick popping out!!!!!
Rob,
Old Apr 28, 2011 | 10:15 AM
Rogeyboy's Avatar
Rogeyboy
If the dipsticks popped out it would suggest too much crackcase/breather pressure...?
Clean all the breathers out and do a comp test/leak test to see if the rings/valves are letting boost pressure by and into the oil system...
Old Apr 28, 2011 | 04:13 PM
Canada1's Avatar
Canada1
Hello Joe,
Are you running a 1.6 cvh? or Zetec?
A .63 rear housing sounds Huge for even a 2.0 Zetec.
How high do you rev this?
Old Apr 28, 2011 | 05:58 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
get the internals upgraded, wish i had done my zetec turbo sooner, would have saved a lot of cash in the long run.
granted it's not far of 5k now with FRS box etc
Wilsfoci
15
Mar 30, 2016 10:26 PM
steerfromdarear
28
Jan 29, 2016 06:14 PM
Bailes1992
Aug 16, 2015 07:14 PM
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
