boost ecu
Old Mar 29, 2011 | 07:00 PM
Patto's Avatar
Patto
Default boost ecu
there is a switch in the dash that goes to the boost ecu to increase the boost of my escort i am wanting to take it out but am unsure how to go about it, i havnt opened up the ecu yet to look but im sure someone will know how its done, is it just a case of removing the wire?
Old Mar 29, 2011 | 07:05 PM
white2lsr's Avatar
white2lsr
What is a boost ECU
Old Mar 29, 2011 | 07:12 PM
juffer's Avatar
juffer
i have never heared of one. Are you sure its not wired into the amel valve to give 2 stage boost?
Patto's Avatar
Patto
i may be wrong, but i was under the impresion that rs turbo escorts have a boost ecu aswell as a fuel one ie Kjet? do you know different as im always willing to learn???
Old Mar 29, 2011 | 07:13 PM
Patto's Avatar
Patto
no it doesnt go to the amal valve, i thought thats were it would go as it does on my other rs turbo so i was suprised when i removed the loom to find it going to my hearts and diomands ecu.
Old Mar 29, 2011 | 07:32 PM
martysmartie's Avatar
martysmartie
The actual name is the fuel ECU this deals with the on load fuelling etc, without this you would have the same management as an XR3I!
The only one I know is as said a "Two stage boost control" this is simply a switch wired into the earth of the amal valve which goes to the ECU, when the switch is closed you run maximum boost but with it open you run lower boost.
Martin
Old Mar 29, 2011 | 07:35 PM
Patto's Avatar
Patto
Martin
and that is how my other car is set up switch wired to amal valve but this one the wire from the switch goes to the ecu, is the amal valve wired to the ecu also? maybe they wired it there rather than running it down the engine bay to the amal valve?
Old Mar 29, 2011 | 07:46 PM
martysmartie
Yes, the amal valve earth is pulsed by the ECU, I personally done mine on the loom itself end as you can't see it and it looks far better than tacky wire splicing showing under the bonnet!
Martin
Old Mar 29, 2011 | 07:53 PM
Patto's Avatar
Patto
Martin
cool i guess thats what they did then, so in theory i can just remove the wire and have 1 boost setting.... thank you for replying..
Old Mar 29, 2011 | 08:07 PM
martysmartie
If bit is that yes, remove the switch and solder the wire.
Martin
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
griffo69
Oct 4, 2015 11:58 AM
Russ Payne
Sep 25, 2015 08:29 PM
