Views on these bolts.....
Would like to know your views on these head bolts. What effects if any will they have on the block with having different torque settings?
http://www.burtonpower.com/parts-by-...s/cv191hd.html
Alright thanks mate. So in a nut shell it dont really matter if you use stretch or non-stretch bolts, both gona do the job. But will you get any movement using stretch bolts when under high pressure?
Wye Valley Hardcore
As I understand it stretch bolts allow for the different thermal characteristics of the iron block and alloy head as they expand and contract at different rates. You should use a stretch bolt on a CVH ideally.
Ok thanks Muz, that does make sence. So i take it then that standard RST head bolts from Ford's will be stretch bolts then? Dont surpose anyone has the ford part number for the standard head bolts?
I agree,
For a low power cvh the factory stretch bolts do a fantastic job.
There is no need to retorque them as well. (That is why the factory used them
in the first place.)
Thanks lads, appreciate the advice. Its not until you start to do a job that you begin to question things ,you know what i mean. I agree with what ya sayin, and gona order up the standard ford head bolts. The ones i took off where standard ones, and have worked well.
Thanks alot
Thanks alot
