Can't get a gear :(
ok, i can select gear no problem at all with engine off.
but once running, can only go up, with difficulty, can't change down.
also when depressing clutch with engine going, makes a little bit of a jangly noise, to make things worse, when the boyfriend got i home for me, it wouldn't idle at all (he was in second) wanted to creep forward
any help, as always, greatly appreciated
![Content](https://passionford.com/forum/images/smilies/content.gif)
thanks so far guys ![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
when the bf drove it home, had to turn it off to get a gear, once started could drive it, just about...
got details on the clutch, its a Alcon 6 plate paddle, question is, it all happened on the same day, fine the day before, hell the next...can the plate really fail that quickly?
also a bit concerned as with all the "syptoms" the haynes manual says that its more likely the selector rods, or synomesh that is more likely at fault?
what do you think?
what do you think?
07-10-2015 12:56 PM
The Youth.
30-09-2015 09:59 PM
