engine rebuild update BACK ON THE ROAD PHOTOS
Old 23-02-2005 | 10:54 PM
  #81
Ramonster's Avatar
Ramonster
Originally Posted by series1ajc
Originally Posted by Ramonster
Very very very nice work mate! You did it all by yourself???
no it was all done by Motorsport Developments, the only thing i did
myself was sort out the powder coating. fitted intercooler my self, thats
about it. will be putting engine back in myself with help from my mate
Well good luck then! I'm planning to do everything that's possible myself... It will be hard that's for sure! I'm just a cook, never did anything technical. But I think it will be allright! Got many help overhere in Holland
Old 24-02-2005 | 05:52 AM
  #82
The Sludge's Avatar
The Sludge
garibaldi
Old 24-02-2005 | 08:10 AM
  #83
Stu @ M Developments's Avatar
PassionFords Creator
Final Pic now its totally finished and sealed for transit just to finalise this topic. Ive left them large so you can click on em if required.
When the clutch arrives i may put that on too as most RST owners will never have seen the new Alcon 6 Paddle.
Old 24-02-2005 | 11:21 AM
  #84
rsturbo90's Avatar
rsturbo90
looks very good mate, saw it yesterday sat in motorsport, rocker cover and inlet looks really good
Old 24-02-2005 | 12:42 PM
  #85
CasperR's Avatar
CasperR
dream machine
Old 24-02-2005 | 04:58 PM
  #86
AJC's Avatar
AJC
WELL CHUFFED WITH THE FINISHED PRODUCT
Old 24-02-2005 | 05:35 PM
  #87
MK5RST's Avatar
MK5RST
How much did that rebuild cost in total? Looks good btw stu
Old 24-02-2005 | 05:42 PM
  #88
AJC's Avatar
AJC
2500, it was going to be 2000 but got the Alcon clutch and a headwork done aswell,
new valves, then there was labour to remove broken head bolts, valve guides and
seats, and a S2 flywheel for the clutch, i have spent approx 3500 with the purchase
of intercooler,turbo being rebuilt to my desired spec, brakes, new hoses, some more under bonnet shiney stuff and the powder coating, dont intend on selling the car any time soon and i inherited the money so i aint to bothered, its the first car
i have had that i have spent a lot of money on. just need to get rear arches
resprayed and then i will be happy as larry
Old 24-02-2005 | 06:35 PM
  #89
MK5RST's Avatar
MK5RST
It looks like its worth the money mate, built ina very clean enviroment, i might get stu to do me a rebuild as ive nearly finished my RST Powered MK5 Fully stripped with cage and seats, with 220 BHP it should go well, thats my aim anyway but the engine has done about 75000 miles so im not gonna bother modifying it till its has a rebuild!
Old 24-02-2005 | 08:29 PM
  #90
We discussed price etc on another topic, but remember that a common mistake made is having an engine built and then changing your mind on specification. This is an expensive error, largely because your engines:
Bearing clearances.
Bore Clearances.
Compression Ratio.
Ring pack Gap.
Camshaft Kit.
& Turbo charger.
Will all be specced to ultimately suit this end result.
Try to get it right NOW rather than be forced to compromise later.
Top of my head, A CVH build to essentially a STD blueprinted spec requires:
Machine work usually required:
Rebore existing block
Bore Honing (cross hatch)
Crank grind / polish
Dynamic Balancing
Decompress pistons
Surface Grind Flywheel
New parts always fitted
Mahle Pistons and rings.
Performance full cam kit.
Crank & big end bearings.
Thrust washers. (U&L)
Oil Pump.
Water pump.
ARP Big end bolts.
Genuine Gaskets and seals.
Genuine Head Bolts.
Cambelt. (Gates OE).
Cambelt tensioner.
Thermostat and seal.
Cooling fan Switch
Dash temp gauge sender
Ford 071 plugs
Dist cap and rotor arm
8 new rocker locknuts
Block to turbo oil pipe
Mineral Oil and OE filter
Labour on top of that work/parts as i have a family to feed the same as you folks
That lot, pans out around Ł2200 all in.
But you may still need.....
Full Cylinder head overhaul:
Pressure test
8 Valve guides
8 valve seats
8 valves re-cut to seats
Surface skim
Block Reface.
Head reface.
Optional upgrades:
Stage 3 big valve cylinder head
Duralloy vernier timing pulley
Cosworth forged pistons.
Steel H section Connecting rods.
Steel crank.
Alcon 6 paddle clutch.
With your engine bill you always get:
A CD with lots of pictures of your engine build in various stages of strip and build. The ones above are resized low resolution versions just to illustrate Andys topic for him. The CD will have about 100 pics in different sections. (Strip/probs/cleaning/machining/building etc)
You also get paperwork which consists of:
Itemised invoice listing every part.
Engine refittment guide with hints and tips.
Engine running in and oil change guide.
Technical spec sheet including bearing clearance big end bolt length, compression ratio and much more.
Im sure most will agree that its good value for money when you look at what you actually get compared to some places that seem to think a few rings and a new set of cheap shells constitutes a full engine rebuild
Old 24-02-2005 | 08:56 PM
  #91
DazC's Avatar
DazC
I think I got a well specced engine for what I paid.
Old 25-02-2005 | 03:20 PM
  #92
adamS2RST's Avatar
adamS2RST
Good Pics Stu. well done....hmmm reeeeealllllyyy need to get some money together!
Old 25-02-2005 | 04:36 PM
  #93
AJC's Avatar
AJC
Old 27-02-2005 | 03:29 PM
  #94
Thanks Daz, im very pleased to hear your happy with her.
Sorry i was a bit short of time to chat yesterday, bloody busy day.
Old 27-02-2005 | 03:46 PM
  #95
Ramonster's Avatar
Ramonster
Old 27-02-2005 | 05:03 PM
  #96
DazC's Avatar
DazC
No worries Stu. You looked pretty busy. I would have stopped later but had to go and get ready to go out. Incidently I was back at home by midnight as I was dropping asleep!
The engine is mint. Just could do with a bit more horse power! We'll see what it can do when I get the "other" modifications on it!
Old 27-02-2005 | 05:10 PM
  #97
AJC's Avatar
AJC
daz, you were right about hi spec, the brakes are fitted but there staff and
customer services are absolutely useless. took 4 hours of fiddling and slight
modification to caliper to fit, and thats just 1, will do other tomorrow as will only
take a bit cause know whats needed where spacer wise.
Old 27-02-2005 | 07:15 PM
  #98
CarlRsT's Avatar
CarlRsT
Sounds like your actually starting to enjoy this spending and modding lark Andy... beware of stepping foot on the slippery slope..roflol
Oh how I'm on that slope
Saw the engine last week
Old 28-02-2005 | 08:24 PM
  #99
Carl... your stood on the slope with greasy shoes pal.. theres no way back up for you
Old 28-02-2005 | 08:32 PM
  #100
Lee Reynolds's Avatar
Lee Reynolds
  #101
DanRSturbo's Avatar
DanRSturbo
Fucking hell Stu, that's amazing work m8
I don't browse tech stuff cos it flow's waaayyyy over my head, but that's mindblowing
Old 28-02-2005 | 08:41 PM
  #102
D_a-RR-e_N's Avatar
D_a-RR-e_N
wow thats what ya call a bottem end rebuild lol,
Im joining some of you guys again ive just bought a S1 needs loads of work doing tho
i got this all to come lol
Old 28-02-2005 | 10:16 PM
  #103
DazC's Avatar
DazC
Do you think that applies to me also?
And maybe even my Dad?!
Old 28-02-2005 | 10:44 PM
  #104
Same shop.. same slope, same greasy shoes
Old 01-03-2005 | 04:46 PM
  #105
AJC's Avatar
AJC
this slope is a bank balance killer
Old 01-03-2005 | 06:11 PM
  #106
Daviet's Avatar
Daviet
brilliant work there stu
cars gonna be amazing when finished mate
and i reckon the work u got done for that price is great IMO
just wish i done the same now tbh
Old 01-03-2005 | 10:23 PM
  #107
DazC's Avatar
DazC
You should be loaded!
Car should be good when it's done though mate. Bet you can't wait! You still gotta run it in as well though! That is boring!
I can't wait until mine is running full power and handling properly.
Old 02-03-2005 | 12:06 PM
  #108
AJC's Avatar
AJC
Me, loaded, no way,
running engine in is going to be a bit of a bore, just going to take a couple
of days of work and sort it out then hopefully,
been told motorway miles are a no go.
Old 02-03-2005 | 12:07 PM
  #109
AJC's Avatar
AJC
stu has pm'd me, clutch arriving tomorrow
Old 02-03-2005 | 08:04 PM
  #110
DazC's Avatar
DazC
Me, loaded, no way,
You have to vary the load on the engine and not keep the revs constant.
I went up Beacon fell, Trough of Bowland and Rivington cos it's up hill down hill and windy roads. Lots of gear changing and varied revs. Plus a bit of town driving and up to Southport/Blackpool via A roads.
Old 02-03-2005 | 09:43 PM
  #111
CarlRsT's Avatar
CarlRsT
Old 02-03-2005 | 10:20 PM
  #112
turbo terry's Avatar
turbo terry
looks top job good idea with the pics of rebuildon cd!
what is burretting???(SP?) what do you use there to check comp ratio?diff to compression test??
Old 02-03-2005 | 11:02 PM
  #113
DazC's Avatar
DazC
The burrette is used to insert and measure fluid into the the cylinders to obtain capacity and compressed volume. From this you can calculate compression ratio.
A compression test is nothing more than a guage to measure how much air the cylinder is capable of displacing, more precisely what pressure.
(X+Y)/Y = Z
X is capacity of 1 cylinder
Y is compressed volume or combustion chamber volume inc head gasket thickness
Z is compression ratio.
Eg. 2 litre engine, 1 cylinder is 500cc and combustion chamber is 50cc (this is only random figures of the top of my head)
The equasion would be......
(500+50)/50 = 11:1
Any help?
Old 03-03-2005 | 04:33 PM
  #114
AJC's Avatar
AJC
now got another set back till wednesday, alcon say clutch not ready
Old 03-03-2005 | 07:07 PM
  #115
Sorry pal,
Im gutted for ya Fookin Alcon messers!
Old 03-03-2005 | 07:18 PM
  #116
turbo terry
gutted for ya!
dazc! so you determine the chamber volume using the burette at tdc?dont laugh i know feck all
Old 03-03-2005 | 08:45 PM
  #117
DazC's Avatar
DazC
Originally Posted by turbo terry
gutted for ya!
Yes.
Old 03-03-2005 | 10:52 PM
  #118
Hardeep_Singh's Avatar
Hardeep_Singh
excellent thread and love the progress pics, engine looks spot on mine was as fresh as that about 2 years ago
question can you workout the compression ratio with the engine built up and in the car?
Cheers,
Hardeep.
Old 04-03-2005 | 04:52 PM
  #119
AJC's Avatar
AJC
decided to go for a AP organic clutch if wednesdays deadline is not met,
need this car back on the road,
cheers to stu for constantly chasing it up
Old 07-03-2005 | 12:14 AM
  #120
Just doing what's required and expected pal, no more.
Sorry its been such a ballache
Quick Reply: engine rebuild update BACK ON THE ROAD PHOTOS
