cts stg2+ limit?
Hi all,
I'm aware most will say ditch it for a mtx box, being seeing as I already have one bolted to the car I wanted to know the safest limit (if there is such a thing) on one of these boxes.
What has been the lowest/highest bhp/psi amount that a box has failed on?
I'm not chasing big numbers on my car,under 300brake is fine and more than enough for me.
cheers peeps
cheers peeps
Turbocharging Technician
my honest theory is, if the bc/ib5 could be miraculously made really bullet proof strong, then why did ford design another gearbag for the mandildo and higher powered escorts and foci? The answer is because they could not do anything with the bc/ib5.
powered by K26
im using the same box as stu collins and its still going strong, did 300+ on the rollers the other day.
saying that, it does worry me how much longer it will last?
the VW boys have the exact same problems with the o2a "crumble box", they are weak and also have a small clutch, the only solution considered with them is to upgrade to an o2J or o2m box, they have all the problems associated with an mtx conversion, making mounts, changing the gearshift, flywheel, driveshafts have to be changed, but once done its fit and forget basically. It seems more and more people are getting this idea in the ford scene now, maybe due to engines making more and more power.
powered by K26
i did my first mtx conversion for Ł50 (the price of the gearbox) well worth it. I made the engine mounts and modified the inner wing myself, modified mk5 escort shafts at work to take mk outer cv joints, and made a custom linkage by welding a mk4 and mk5 escort one together.
My CTS Stage 1 box is still going strong after 7 years of thrashes an dtrack days with 260bhp and similar torque. My chosen tuner also says I drive like an animal too
powered by K26
SMILER258
28-09-2015 09:04 AM
wheelwizardrefurbs
18-09-2015 08:59 PM
Si B
12-09-2015 06:49 AM
