Removing sunroof tray?
Old 24-01-2011 | 03:24 PM
mattseries2's Avatar
mattseries2
Default Removing sunroof tray?
Who done this?
It look like its glued in with a few spot welds?
Anyone explain the best way to remove it.
Old 24-01-2011 | 04:18 PM
muz's Avatar
muz
Wye Valley Hardcore
The actual part of the roof, Matt? Or the sunroof cassette?
Old 24-01-2011 | 06:18 PM
mattseries2
The cassette mate. The bit the actual sunroof sits in under thw roof.
Old 24-01-2011 | 06:22 PM
nigel b's Avatar
nigel b
the back part is bonded and 2 strips go under the roof near the tailgate
it is welded to the roof where the sunroof goes,you will see the koin along the edges
Old 24-01-2011 | 06:48 PM
mattseries2
Best way of removing the spot welds? Ive got a spot weld drill bit but i dont want to go right through the roof.
Old 24-01-2011 | 08:54 PM
little bram's Avatar
little bram
Just take it easy with the drill mate. and take care when removing the tray. if you dont cut the sealer/bonder and try to pull it from the sealer you will crease the roof mate, the roofs are realy thin when you take the tray out.
lee
Old 24-01-2011 | 09:09 PM
mattseries2
Will giv that a go mate. Not so important keepin the roof mint as i have a carbon one goin over the top but still want to keep it as neat as possible.
Old 24-01-2011 | 10:17 PM
nigel b's Avatar
nigel b
i wouls try to remove the spot welds before the tray
it will be a long boring job but take your time
Old 26-01-2011 | 06:18 PM
jme-rst's Avatar
jme-rst
when I removed my sunroof I just pulled it all out,no crease in the roof left,just a big gaping hole,if you're not going to be using te sunroof then it doesn't matter if it gets a bit mangled,mine would have been unusable after I removed it
Old 27-01-2011 | 06:07 PM
tazla's Avatar
tazla
here u go i did mine a while ago on my s1 hope this helps keep scrolling til you find it http://www.seriesoneturbo.co.uk/show...?t=5191&page=3
Old 27-01-2011 | 06:15 PM
mattseries2
Cant get on there mate says i need username/password.
Old 27-01-2011 | 06:36 PM
tazla's Avatar
tazla
uuups sorry.join the site its a doddle.
01-11-2015 06:53 PM
07-10-2015 12:56 PM
Fudgey
21
30-09-2015 06:19 PM
stevecfrst1
30-09-2015 05:18 AM
Orion_Gav
29-09-2015 04:50 PM
Quick Reply: Removing sunroof tray?
