which wires run to fans
Old 10-01-2011, 05:07 PM
MARTCOS
MARTCOS
MARTCOS's Avatar
Default which wires run to fans
ello ppl just seeing if anybody knows which wires run to the fans as the previous owner cut a whole load of wires and struggling to relocate them, ive got the main wires coming off the fan itself but anybody know where these connect to.
cheers ian
Old 10-01-2011, 05:29 PM
orionmojo
orionmojo's Avatar
There should be a black miltiplug on the loom on the drivers side, infront of the rad and sits on the crossmember. The wires are brown and black, so pretty bland and will probably blend in well if they've been chopped.
Good luck!
Old 10-01-2011, 07:51 PM
MARTCOS
MARTCOS
MARTCOS's Avatar
ok cheers mate i shall have a look in the morning hopefully wont be to much trouble to locate with any luck.
Old 12-01-2011, 12:13 PM
stevo123
stevo123's Avatar
IIRC they go past the drivers strut tower elong the inner wing before they get to the position mentioned above if that is any help. (There is a plug there that can be shorted to switch the fan on for setting timing etc as well). I always thought is was strange that ford recommend the fan running before setting ign timing - guess it has something to do with putting some load on the engine?
Old 12-01-2011, 04:12 PM
MARTCOS
MARTCOS
MARTCOS's Avatar
cheers ppl all sorted the wally who had it before cut the switch off the the wires leading to the fan and just left the black and brown wires loose, but then put in a manual switch.
couldnt work out why just the manual switch, and not run both, surely it would of been easier if they cut in themselves and then if you needed to switch the manual on? lol
anyway all sorted and back to how it should be.
cheers
ian
Old 13-01-2011, 09:49 AM
essexRSTSouthend
essexRSTSouthend's Avatar
While on the subject,running two fans on the original wires safe? Just wondering,as i've currently fitted my new fan switch from msd.Before i was running manual switch on different wires.
Old 13-01-2011, 04:28 PM
essexRSTSouthend
Any advice be great.
Old 16-01-2011, 12:42 PM
MARTCOS
MARTCOS
MARTCOS's Avatar
as long as the wires are are all good and its fused i cant see it being any problem to be honest.
Old 16-01-2011, 01:10 PM
essexRSTSouthend
Ok cheers for that.
big_Rad
15-09-2017 09:36 AM
YODI
30-08-2015 01:12 PM
kosienutter
31
22-08-2015 09:55 AM
Zoggon
10-08-2015 10:39 AM
yawiejon
15
09-08-2015 06:36 PM
Quick Reply: which wires run to fans
