Running lumpy when cold
Old Jan 10, 2011 | 09:59 AM
kermitt's Avatar
kermitt
Default Running lumpy when cold
Got the car out the garage this morning to get it MOT'd today and it ran lumpy and rough till it had warmed up and was fine although hunting slightly at idle. Has been in the garage since the begining of Dec due to the snow and ice.
The only thing I have changed recently is the thermo time switch (brown sensor at the back of the head).
Previously the cold start needed to be plugged in when cold and unplugged when hot and it started no bother.
Am assuming that my idle mixture must to too rich on startup hence the rough idle?
Will be getting setup again once MOT'd & taxed.
Old Jan 10, 2011 | 12:15 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Could well be different now you changed the TTS, will probably need a look at on an AFR machine and poss a setup/tweak of the idle mixture.
xrmalin
Sep 13, 2015 06:52 PM
Eigdoog
Sep 13, 2015 05:46 AM
stevierob
Sep 7, 2015 07:09 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
gingeRS
Sep 4, 2015 06:29 PM
