Help needed with setting boost....
I've recently had my engine rebuilt and during the running process turned the boost down to assist.
Otherthan having the car setup... Is there a technique when setting the boost? What will happen if it over boosts?
I'm currently running a standard ecu.
If you are running a std ECU you wont see more than 9-10psi IIRC.
The only advice I would offer is take it to a tuners and have it set up. There is alot to take into account when increasing boost and if you have just rebuilt its not worth running the risk of damaging a fresh engine.
Not worth messing up your engine for the sake of a few quid to get it done properly
shit happens
yeah sayin that tho if he has the amal valve bypassed he will have nothin to restrict the boost to 8-10 psi, how did u turn boost down mate? do u have a bleed valve or did u do it via actuator? either way as said u should get it set up at a tuners if u donnt knoow what your doing
How comes i can run 20psi in my escort rs and doesnt over boost ? its still got the amal valve too but does have a bleed valve too, Not sure on ecu as its been like this when i got the car and has not really missed a beat
The boost WILL still be restricted even if you bypass the Amal valve which would be a crazy thing to do as the standard map will not allow more than 10PSI max.
As to OP question as said you need to get it setup, it's not just a case of running more boost you need the fuel to go with it as well as well as correct timing curves, a whole multitude of things need to be setup.
Martin
kosienutter
31
22-08-2015 09:55 AM
