smaller alternator belt for s2 erst
chaps,
when i fit my bigger intercooler,double fans,alloy rad , my alternator fan blade bit is about 10mm from the bottom water hose on my rad.
the cure i think has to be a alternator belt which is a bit shorter than the standard one.
loads of peeps must have the same problem.
is there a belt from another car that fits or do you shorten hoses or what?
thanks guys
thanks guys
Id just go into a motor factors and get them to pull up on the screen how long an rs turbo one is and then get them to have a look for one thats abit shorter then give it a try
i bought a rad of ebay and the bottom hose to the water pump came out at the wrong angle touching the alternator! i rang the ebay shop i got it from and they agreed to refund half the cost if i could use it so i popped to motormania and borrowed all belts that were shorter than the s2 belt. 762 will give you room. be better off moveing ic and rad forward imo.
jonfoc
16
11-09-2018 05:35 PM
Mc5506
05-10-2015 09:57 PM
