X-low apex springs
hello chaps, Need a bit of help recently bought some bilstein's and apex springs for my s2 been told they are 40mm but looked on apex website and they dont make 40mm and the x-low ones are 60mm and have the same model number as whats on mine, am i right in thinking that if they are 60mm they will they be around 35-40mm on an rst?? any help much appreciated.
cheeRS
cheeRS
this is what i am trying to get at they dont make 60mm springs by apex for the rst only the 3i and base models, so an rst wouldnt sit at 60mm it would be more like 35mm-40mm correct as the suspension set up is different on a rst??? I normally go for pi springs which are 35mm and they sit nice as did the chassis dynamics 25mm but they dont make the chassis dynamics anymore!!! i certainly wouldn't be going any lower than 35mm-40mm as i know how much they suffer with handling, speed bumps etc etc
ahh I see what you mean now.
I thought it was the 3i and rs models that were an inch lower than the other mk3/4 models?
I'm not sure what the difference would equate too in size drop? I dont know whether it is the set up or the stock rst springs that give the std lower ride height.
I can see why you are questioning it now. its got me confused!
as for apex 60mm they will be roughly 15mm difference from a standard escort to a rs turbo so 45mm is realistic,
Try the PI springs mate as they make for a whole host of companies including cobra springs.
try th apex rear sprngs on first and see what you think of the ride height as you never know they may not be that low, and apex i have heard they are very good springs too.
SMILER258
28-09-2015 09:04 AM
