BROKEDOWN! FUEL PUMP PROBS!
got a bit of a problem, its not on my RS tho, its the Xr3i
the fuel pump isn't working, this happened bout 3 weeks ago and all needed to do was replace the yellow relay in the fuse box, happened again 2 days ago so went and bought another relay but it still isn't working
guessing now its something todo with the pump or wiring!
what do i do? is it an easy fix? i dont even know where the pump is or the wiring too it!
CheeRS
dave
CheeRS
dave
Had loads of trouble on my old S2, spent more time on my back under it sorting the wiring out then it working
In my case it was the conectors that go straight to the pump which were knackered and making a loose conection. I got a new connector and it was fne
bugger, problems, got a fuel pump of my mates E reg XR3i what he doesn't use anymore.
went back to my car to fit it, to fit that is different with it being an EFi model! couldn't even find the fuel pump
anyone know where it is?
top of the tank mate like 2i's
mite be able to get to it under ur rear seat like a 2i but i doubt it
try a positive wire to the black and red wire that goes 2 the pump b4 pullin ur car apart
mite rule out the pump it it starts working
nice one cheers, checked under the seat and couldn't see anyway of gettting in! looks like i'm gonna av to remove the tank!
been told bout a switch in the spare wheel well, gonna check that out first! hope its only that
ahhh,,,,wait a minute, arn't the fuel pumps on efi's inside the tanks? I though't the FRST one was inside the tank, but as posted above is it just "on top" then? Never seen a FRST underide really so unsure, interested to know tho as I was looking for a tank for my s2 not long back and had a debate about the fuel pump / swirl pot etc
JK12
33
26-04-2021 12:09 PM
155lee
24-10-2015 11:11 AM
