windscreen rust
Old Nov 29, 2010 | 07:12 PM
PETEDUDE007's Avatar
PETEDUDE007
Default windscreen rust
ok from the inside of my car with the dash out i can see rust marks where water has been running down in the seal from the windscreen corners.
now there is no visible rust in or out the car around the seals but i bet there must be behind the seals.
so iam looking to get this fixed soon.
i was just wondering if anyone had this done before and how much they think a body shop would charge for removing and fitting the screen again plus taking care of any rust! and a new seal.
i will try n buy the seal with out going through them.
just need a rough idea as my body guy cant manage and i want it done soon.
Old Nov 29, 2010 | 07:14 PM
155lee's Avatar
155lee
its easy to take the screen out,just work round it with 2 screwdrivers being ultra careful not to break it.as for the rust,it may just be the lip thats gone which will be easy to fix,or it may be the whole corner.did you see my shell when you were down,that was gone in 1 corner.
Old Nov 29, 2010 | 07:28 PM
PETEDUDE007
yeah i did the bottom right! it was pretty fecked. did u keep the shell to rebuild again another day!?
well what puts my body guy off is he is feart o breaking the windscreen as he has broken one before and he hasnt got room in his workshop as he has about 7 other cars in there,i dinna want to harass him as he has done a top job so far plus its only in his spare time as he is retired now.
so hopefully it is just the lip.
Old Nov 29, 2010 | 07:37 PM
neil andeRSon's Avatar
neil andeRSon
if your getting a new seal then cut the old one. get a sharp blade and lay it flat on the glass on the outside and cut through the old seal.
Old Nov 29, 2010 | 07:48 PM
155lee's Avatar
155lee
shell got scrapped,couldnt be bothered moving it into my pals damp garage.either work the rubber out,you could do it with your fingers once you get started or cut it.i had a spare seal but gave it away last week
Old Nov 29, 2010 | 08:52 PM
luke19790_3's Avatar
luke19790_3
like this
Old Nov 30, 2010 | 03:32 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
yuk.
Old Nov 30, 2010 | 07:04 PM
PETEDUDE007
im nae so much fussed about removal tbh that looks relatively easy.
im more concerned about how much a body shop would charge roughly for carrying out the whole job rust n all!
this is a job i want done by professionals!
Old Feb 25, 2012 | 07:10 PM
matty325's Avatar
matty325
fkn hell luke did you get that fixed ,im about to remove my windscreen on my series 2 as its leaking started strippin off all my underseal to paint my floor and ended up needing 2 sills inner and outer and floor welded going to do a full post on it once ive got all the pics it wont be seeing the road this year
Old Feb 27, 2012 | 11:35 AM
luke19790_3
not sure, found more under the dash on both sides
Old Apr 22, 2012 | 08:37 PM
duk2's Avatar
duk2
Hey loon don't worry about takin the windscreen out il do it 4 u, iv done heaps plus I hav a spaire and if ur quick iv still got that shell iv just cut up and the corners on it r fine so u could cut them out and hav ur guy fit them!
Old Apr 26, 2012 | 01:28 PM
New Shell Dude's Avatar
New Shell Dude
It shouldn,t cost you any more than £40 to £50 to have the screen removed and re fitted.
Old Apr 26, 2012 | 01:37 PM
New Shell Dude
If its a heated screen and your gona do it your self don,t forget to take the screw out of the earth connector its under the digital clock on the head liner.
Nov 1, 2015 06:53 PM
