it is two seperate bit..there is a plastic case that holds all the fuses etc, and sits inside another case..you need to prise the inner bit out and lift up..this will reveal 3 (i think) screws..undo them and the whole thing will lift up..hope that explains it enough for you
wont lift up much if the harness is still connected inside the car..careful not to pull too mmuch cos the wires dont take a lot of yanking before they break..
