Wet drivers side carpet...
I noticed a wet carpet the other day, so dried out the carpet.
Now, it gets wet while the car sits outside my house, not moving.
I can lift the carpet, and the actual floor is dry.
Under the fuse box apears to be ok (I can lift it a couple of inches) and there appears to be a white rubbery seal around it that seems ok.
Someone (not Ford related) said possibly the sunroof drain. Could it be this?
Any other sugestions?
Might worth checking if your heater matrix, mine leaked and made my carpet wet only noticed cos i put some of that green water wetter stuff in and floormats showed it up.
Will it ever end !!!!!!!
Heater matrix is my guess - stick the motor through a carwash and when you see a small foam swimming pool appear in the footwell you know thats the problem.
Alternatively (recommended) - check the heater vents that are located behind the centre console (used to heat your feet) - feel around the vents and if water is on them then yes defo the matrix.
07-10-2015 12:56 PM
