Putting the power down.........!
Old 18-11-2010 | 10:41 AM
S2Dan's Avatar
S2Dan
Default Putting the power down.........!
Just after some advice, and peoples ideas on how to transmit a big producing, big power RST to gettin that power down on the ground??
Change of gearbox and diff, probably a good start, any other tricks, or tips?
Old 18-11-2010 | 10:45 AM
chaffe's Avatar
chaffe
Turbocharging Technician
drive backwards, in essence making it RWD
Old 18-11-2010 | 10:46 AM
s1cab's Avatar
s1cab
tyres make a huge difference. adjustable tca's every little helps
s1cab's Avatar
s1cab
muz's Avatar
muz
Wye Valley Hardcore
Ditch the crap, standard front ARB and get an RS1600i item on.
Old 18-11-2010 | 10:53 AM
chaffe's Avatar
chaffe
Rev limiting type traction control is available from most aftermarket ecu's, what ecu does it run? this may be an option.
Old 18-11-2010 | 11:03 AM
s1cab's Avatar
s1cab
https://passionford.com/forum/ford-e...the-power.html
this will help !
Old 18-11-2010 | 11:55 AM
Rogeyboy's Avatar
Rogeyboy
Does the Series1 ARB really make that much diff on a Series2?
Is there any other upgrade for the Front/Rear ARBs?
Old 18-11-2010 | 12:00 PM
muz's Avatar
muz
Wye Valley Hardcore
Will make loads of difference to how it drives. RS1600i is also better than a Series one as it has a one piece alloy mount and a thinker ARB.
Old 18-11-2010 | 12:04 PM
S2Dan's Avatar
S2Dan
Thanks lads, some good points.
That other thread is quite interesting, some good points in there aswell.
Where can you buy adjuctable tca's, do burtons do um?
What about focus RS box? Also any ideas on any mods which can be done to make the drive shafts the same length?
Old 18-11-2010 | 12:20 PM
s1cab's Avatar
s1cab
adjustable tca's from compbrake or mef
Old 18-11-2010 | 12:36 PM
dave_s2_rst's Avatar
dave_s2_rst
i thought mef don't exist no more?
where can the rear adjustable set be brought from? is it still available?
cheers
Old 18-11-2010 | 01:28 PM
PaulT's Avatar
PaulT
If you have adjustable dampers set the rear harder than the front helps on my S1 no end
PaulT
Old 18-11-2010 | 02:11 PM
Rob_DOHC's Avatar
Rob_DOHC
Originally Posted by s1cab
LOL i just read the whole of that old thread, just confirmed what an idiot morph is.
Rob,
Old 18-11-2010 | 02:30 PM
S2Dan's Avatar
S2Dan
Thanks mate, i look into these.
Old 18-11-2010 | 02:52 PM
mattseries2's Avatar
mattseries2
are mef still going? If so is there a website or anything?
Old 18-11-2010 | 03:43 PM
s1cab's Avatar
s1cab
not sure i've got compbrake ones on mine.
Old 18-11-2010 | 03:50 PM
dave_s2_rst
don think they are, compbrake do the adjustable tca,
just wondering if the rear set up was in the pipe line from them to?
Old 18-11-2010 | 04:08 PM
JamboRS's Avatar
JamboRS
focus rs 1672
Rob,
he was a clueless twat,full of misinformed info that he read somewhere or was told about
Old 18-11-2010 | 04:22 PM
Rob_DOHC's Avatar
Rob_DOHC
God he's a tool lol
Old 18-11-2010 | 06:27 PM
stuart collins's Avatar
stuart collins
true and d4 was even worse, wish i had took sum pics of d4 s car b4 it was taken to bits what a mess u would not believe
oh yeah and morphs car was actually makin 180 bhp @28psi(flywheel) when he was quoting 300+ lol
Old 18-11-2010 | 06:37 PM
Karlos G's Avatar
Karlos G
Balls Deep!
FPMSL!!!!
With regards traction, I have no idea! I get wheel spin in 1st through to 3rd in the dry and in every gear in the wet lol
Running Pirelli PZero's and Spax adjustables standard everything else.
Old 18-11-2010 | 07:48 PM
Rob_DOHC's Avatar
Rob_DOHC
D4's was stripped!
And honestly how the fuck can you make 180brake @28psi? that can't be possible can it? Im hoping for over 250 @25psi lol
Rob,
Old 18-11-2010 | 07:54 PM
chaffe's Avatar
chaffe
the only time i see 28 psi is in my tyres
Old 18-11-2010 | 08:27 PM
caprizetec170's Avatar
caprizetec170
best thing to get power down would be equal length drives, good lsd, adustable tca,s coilovers, separate rs1600 type tie rod and rollbar, plus replace all bushes with rose joints. stiffer engine and gearbox mounts help alot too
Old 18-11-2010 | 08:33 PM
chaffe's Avatar
chaffe
no one has mentioned running lower tyre pressures?
Old 18-11-2010 | 08:37 PM
Rob_DOHC's Avatar
Rob_DOHC
As to putting power down, depends where.... drag or road.
1/4 mile wise, stiffening and raising the rear end whilst lowering the front end will help as there will be less dynamic weight transfer to the rear.
The aim is to keep the wheels/tyres normal and square to the tarmac. Hence adjustable bottoms arms etc. Not sure how much the 1600i set up will help with straight line grip, probably loads with handling etc.
Tyres,
Your foot
Equal length shafts should help with torque steer, not so much grip i wouldn't have thought, but the car would certainly be less of a handful.
Rob,
QplateRST!'s Avatar
QplateRST!
1/4 mile beasty!!!!
Coilovers and polybushes made the most differance with grip with my fiesta although a good choice of tyre will help massively
I have a set of nangkangs on some spare wheels leaves blacklines in third where grips third on eagle f1's most of the time!
Old 18-11-2010 | 08:40 PM
Rob_DOHC's Avatar
Rob_DOHC
Never worked that well for me, up until a point it did, found 26-28psi was best for me, gained .2 sec @ santapod, dropped them to 24psi and gained .3 secs lol need to be a happy compromise.
Rob,
Old 18-11-2010 | 09:03 PM
jammerrs's Avatar
jammerrs
your choice of tyres will make a big difference, some semi slick road legal jobbies will have more grip than a normal road tyre for example.
and as has been said, it depends if your wanting to do corners too or how far you want to go with it. as you wont be able to lift the back end on really hard springs if you want it to handle well to
Old 18-11-2010 | 09:09 PM
Karlos G's Avatar
Karlos G
Balls Deep!
D4's was stripped!
Rob,
Piss poor mapping and a really bad VE?! lol
Old 18-11-2010 | 09:22 PM
project rs's Avatar
project rs
hey karl you had a play with your ignition map yet to see if you could get that turbo spooling quicker and tried the popping and banging settings, it sounds ace if you happen be on some country lanes and dropping it down into corners sounds like you've got als
Old 18-11-2010 | 09:40 PM
morph's Avatar
morph
if you think my car was running 180bhp then all I can say is that I am very disappointed with jamsports mapping!
And I was not disappointed at all. The figure was 250bhp+ with the clutch slipping @ 26psi
Matt and Jamie did a spot on job so I can't thank them enough.
If you believe the figure was 180bhp then I was obviously told different from that. But 28psi making 180bhp even a shit map would get better results than that.
Old 18-11-2010 | 09:43 PM
morph's Avatar
morph
Or peeps chatting s h i t as usual!
Old 18-11-2010 | 09:56 PM
Rob_DOHC's Avatar
Rob_DOHC
Woops
Old 18-11-2010 | 10:11 PM
12_Second_rst's Avatar
12_Second_rst
Lol fail
Old 19-11-2010 | 06:05 AM
stuart collins
it stated at 180 when u dropped it off and finished at 250ish , so that means at brunters in jan u had around 180 which would be about rite for the times u were runnin,
just feel sorry for the guy u sold it to and the bull shit u feed him 300bhp with your anti lag like on you tube lol
Old 19-11-2010 | 06:13 AM
stuart collins
and a poorly built engine that dont work together
Old 19-11-2010 | 08:05 AM
S2Dan's Avatar
S2Dan
With the same size drive shafts, if you use a FRS box, is the arrangment so, that the shafts are equal length anyway?? If not how do you achieve equal length shafts?
What diff is in the FRS boxes, or what would you recommend?
What coil overs are best for escort turbo?
Cheers lads
Old 19-11-2010 | 10:10 AM
morph's Avatar
morph
why feel sorry for him? matt told him the spec, and i showed him the graphs of 250bhp so where did you get the 300bhp i bullshitted about to the guy?
as for the youtube vids yes i will remove as the car was not 300bhp but i did not state it was at brunters nor when selling so thanks for that.
as for any anti-lag and engine spec i can only say what the tuner told me was the spec not what i just made up out of thin air.
Any way i had jamsport sort my car and from there i learnt a valuble lesson that if you want the job done right go to a reputable tuner - like jampsort.
Quick Reply: Putting the power down.........!
