Running problem!
Old Jan 25, 2005 | 08:59 PM
JaysS2TURBS's Avatar
JaysS2TURBS
Default Running problem!
I have mentioned this before in another post. When i start my S2 up from cold it fires up ok but then it starts to miss fire when i rev it and then the revs just drop down to 3-400 rpm i have turned up the revs but when the engine is properly warmed up it revs to a 1000 or just a bit over. I have changed my injectors and spark plugs but has made a small difference but its still miss fires when cold. I was thinking if the car was running a bit rich would this cause the problem. How would the car run if it was running lean or rich pls let me know any advice on this would be appreciated One other thing if you think my car is probaly running a bit rich do you think i should adjust the metering unit slightly by turning the screw anti clockwise to lean it off
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
