bolt to stud and nut conversion
RS geek
Hi all does anyone know what length and thread pitch studs i need to do this iv'e had the hubs drilled out and im doing rear disc conversion aswell also any pics if possible thanks guys
just go your local scrappy and knock some out of any ford you happen to find mondeo, focus, fiesta etc they all do the job then just fit them into your drilled hubs job done for less than a fiver
FloydH (08-07-2019)
I got my studs from burtons or rally design, like project said, just drill your hubs out and press the studs in. Best to use a pillar drill if you can etcetc. I also heated my hubs and stuck my studs in the freezer.... you don't really have to but i have a press at home so went for a really tight fit.
Good luck
Rob
Good luck
Rob
mk3ste
17-10-2021 10:09 AM
DavidK
27-09-2015 02:55 PM
