tappets
addicted to boost
are these easy to change? my car has just started tapping so i assume there on there way out, i know they do make a slight sound but its gone a lot louder. had a quick look in the haynes manual but doesent say to much i dont think. are they also called camshaft followers??
Thats the ones mate. Not hard to change at all. Rocker cover off the take off the rocker arms and they should just pull out. Make sure you soak the new ones overnight in oil so they fill with oil.
Turbocharging Technician
you can get a std cam and follower kit for about 85 quid from most motor factors, i fitted a kent cam before and tbh never felt any difference over standard, not sure its worth the money on a cvh, this was timed properly with vernier pulley, cant say i noticed the difference.
addicted to boost
just had all of the rocker arms off and noticed that 1 follower sits higher than the rest (about 1/4 inch) is this normal? the rest of the followers sit flush with the head
Wye Valley Hardcore
One will always sit higher as the valve is open because of the camshaft. And always change a camshaft and followers together as they "work harden" together. A work hardened cam will tear the soft new lifters to bits in minutes.
foreigneRS
Technical essay Archives
20-07-2004 11:29 AM
foreigneRS
20-07-2004 11:15 AM
foreigneRS
20-07-2004 11:06 AM
