Removing abs & how to make new brake lines help needed
Hi
Want to remove ABS system of my RS Turbo so I need to make new cooper brake lines from Brake master cylinder to the brake distributors which are located inside inner archs,
any one know thread size of Male Nut Fixings of Brake master cylinder outlets? Seem to be differents in size............
![](http://img830.imageshack.us/img830/9755/salidasbombafreno.jpg)
Many thanks in advace for help.
Hi anvini the small male nut is M10 x1 size and the other is M12x1 both will be for 3/16 brake pipe, just pop to your local motor factors they should have them in stock.
Hope this helps
Hope this helps
Turbocharging Technician
alternativly you can just re-use the nuts mate
unless you need extra ones? Are you going to blank off the feeds to the abs or change the resevoir?
Many many thanks for the info mate!!!
Yesterday, a friend told me that the size of smaller male nut is M10x1 so I needed to know the bigger one, I though that would be in Metric too.
I have just look for buy them but seems to be 2 types of M10x1 male nuts, LONG and SHORT.
I must buy the SHORT??
Hi
Spanner monkey
whenever i remove the abs, i just use the original pipes, you can re shape them by the gear linkage and join them back together, just need to put one new end on!!
track.focus'd
12-08-2015 05:53 PM
Red_bull
09-08-2015 08:34 AM
