abs question
Alright chaps.
Im in the middle of replacing m box and its really to go back in basically the problem i have is that i have snapped the abs belts and cant be assed to get replacements.
so can i jsut put the abs setup back on without the belts and cable tie the sensors shut so i dont get any dash lights and so it will pass its mot ?
its a s2 1989
p.s i dont wana completly remove the as system yet.
its a s2 1989
rs turbo and xr3i, cabrio etc, abs lamp should come and go off with the handbrake light, thats the correct sequence, so either tie wrap the switch's closed (the belt tension switch's that is) 0r bridge the wiring on the plugs.
For mot the light has to follow sequence described on the vts (mot computer)
Even if components are clearly missing as long as the light follows correct sequence its
PASS & ADVISE
PASS & ADVISE
PASS & ADVISE
PASS & ADVISE
So i can just tie wrap the switchs ? saves me speding the money on belts ......
