brake lights stuck on?
Twistin me melon man
on my mondeo it was the bracket near the brake pedal which holds the switch for the brake lights, the bracket had slightly bent away from the pedal. very simple fix.
otherwise check your earths to the rear lights, wiring to the brake pedal switch etc
happened on mine..i just put a bit of wd40 round the pin that moves, and pressed the pin for 5 mins to work the wd40 in..mine was just clogged up with a bit dust n stuff..yours might not be but maybe worth a try
Dr. Ickxs
15-09-2015 10:15 PM
