help with lights....
Old Aug 16, 2010 | 09:27 PM
atti's Avatar
atti
Default help with lights....
when breaking and inecating at the same time the whole left cluster flashes..bad eath????where would i start?
Old Aug 17, 2010 | 06:16 AM
atti's Avatar
atti
anyone?
Old Aug 17, 2010 | 06:23 AM
chaffe's Avatar
chaffe
Turbocharging Technician
is it an older car mate?
Old Aug 17, 2010 | 06:24 AM
atti's Avatar
atti
yer i think
Old Aug 17, 2010 | 06:32 AM
chaffe's Avatar
chaffe
sounds like a bad earth then, run a new earth wire to the body from the earth on the cluster, failing that the terminals in the cluster prob need a clean up with some emery and a spray with wd40 after.
Old Aug 17, 2010 | 08:35 AM
atti's Avatar
atti
Cheers will try it
Old Aug 18, 2010 | 08:52 AM
martysmartie's Avatar
martysmartie
Will be earths, classic disco lights as it's old RST all that should need doing is the earth connections cleaning as they will have corroded.
Martin
Old Aug 18, 2010 | 02:23 PM
essexRSTSouthend's Avatar
essexRSTSouthend
I found cleaning the connectors to the back lights fixed my problem,had exactly same problem as you.
Old Aug 18, 2010 | 03:10 PM
atti's Avatar
atti
Ok lads thanks for the quick replys
thebronze
Mar 6, 2013 10:25 AM
rsmark86
May 29, 2011 12:46 AM
DaveEscos
May 1, 2006 12:09 AM
DazS1Turbo
Sep 29, 2004 10:46 PM
