brake question on a 1.3 shell
Old Aug 13, 2010 | 01:23 PM
sionr's Avatar
sionr
Default brake question on a 1.3 shell
im reshelling my turbo and just wondering if i could use the 1.3 servo and lines.
does the servo act as a bias on the 1.3 as there is a line going staight to each of the rear drums
thanks
Old Aug 13, 2010 | 03:08 PM
drsrst2zvh's Avatar
drsrst2zvh
You can use all the original lines and servo its probably better as you ditch all the abs crap.
Old Aug 13, 2010 | 03:12 PM
RSandy's Avatar
RSandy
i ran my 1.3 brake line and servo set up when i converted mine, had no problems at all, just swapped the front brakes for the rs kit to ditch the 1.3 solid disc set up, n left the rear drums alone
the only real difference in the system is the 1.3 will have the rear bias pots on the bulkhead
Old Aug 13, 2010 | 03:13 PM
jonny s2's Avatar
jonny s2
ive known people to just change the front brakes
Old Aug 13, 2010 | 04:31 PM
EssexMikeSi's Avatar
EssexMikeSi
andy this is what lines i have on my turbo, with those bias pots. I wondered if they'll work sufficiently for rear cossie disc conversion.
Old Aug 13, 2010 | 04:40 PM
sionr's Avatar
sionr
which was going to be my next quesion
Old Aug 13, 2010 | 04:41 PM
sionr's Avatar
sionr
oh and thanks for the replys
Old Aug 13, 2010 | 05:01 PM
xrmalin's Avatar
xrmalin
Ive left all my 1.3 stuff on the estate and ive got 4 pots on the front and swopped the rear drums to rs turbo jobbies theres a little abit of pedal travel but the brakes pull up spot on.
Mark.
Old Aug 14, 2010 | 07:37 AM
EssexMikeSi
yeah we've bleed my system twice and i couldnt really get a good pedal feel. Plus where its sat there doing nothing it seems to have lost fluid somewhere. Pain in the arse completely.
Old Aug 14, 2010 | 11:49 PM
RSandy's Avatar
RSandy
mine was exactly the same, pedal felt a bit spongy at the top, the brakes worked fine when pressed, but the initial sponge didnt fill u with confidence. bled the system god knows how many times, including pressure bleeding machine thingy, no change
wonder if its to do with the bias pots, or the smaller master cylinder?
iv done away with my 1.3 kit now, fitted an rst master, and the bias pots r gone and replaced with a proper in car bias valve, so fingers crossed the spongy pedal wil be gone
Old Aug 15, 2010 | 07:23 AM
EssexMikeSi
yeah thats what i need to do with mine really but ive never done anything like that before. Now you've changed it do u get a much better brake pedal feel?
Old Aug 15, 2010 | 12:04 PM
RSandy's Avatar
RSandy
id love to tell you, but the car hasnt been driven for 5 years, and the brake set up is in a box on the roof of the car lol
im holding out high hopes that it will be improved tho
Old Aug 15, 2010 | 06:17 PM
EssexMikeSi
lol ok then. If it makes u feel any better mine hasnt been on the road properly in 4years. When i think about it i wonder if the engine will just go bang the first time i boost up as it hasnt been used for that amount of time.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
focus2351
Sep 9, 2015 09:33 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
