zetec turbo in to s2 rs question
If you are going for ZT then I hope you have plenty of points space on your license!!! they are bonkers
if your using the standard gearbox you dont need to cut chasis leg or weld a mount on, all you need to do is slightly modify the standard cvh engine mount to take the 3rd bolt
exactly the same as you would for a zvh
have even seen people just cut the lug off and use 2 bolts although its just as easy to weld the bit back on and do it properly ill try and dig you a picture of what you need to cut
easy peasy
12
easy peasy
12
Do a search mate as im sure crazycage is fed up of writing it lol.
For a MTX box you need:
Mtx box (focus rs one idealy)
Custom shafts
Top gearbox mount welded on inner wing
Focus rear gearbox mount
Gearstick + cables from Mtx Focus
2.0l zetec flywheel
I think thats it, im sure crazycage will correct if im wrong?
Matt
Custom shafts
2.0l zetec flywheel
Matt
