can i use a chipped s1 ecu in my s2/chip question
i want a chip for my s2 but dont want to spend hundreds getting 1.my car is an 1989 s2 90 spec with the knock sensor,cant remember what colours it is but its not hearts and diamonds,its red and black squares.i have found 2 s1 blue red blue ecus close to me with turbosystems chips.can i take the chip from the s1 ecu and use it in my s2 ecu?or will the knock sensor facility cause a problem?also the chips are both turbosyatems,1 is a silver top and the other a blcktop iirc,anybody know the difference?ta,lee
..BS Motorsport..
dont even have to swap the chips over, just put the s1 ecu in your car, knock sensor is a load of shite anyway. Not sure on what you mean silver top / blacktop?
..BS Motorsport..
in the garage
i have a series 1 ecu on mine mate but i had 2 swap the chip over as karlos sez they dont work. just disconect the knock sensor like you said load of shite n they retard the engine like fook thats why my tuner fitted me a series 1 ecu but swapped my chip over.
DixieTheKid
14-09-2015 09:04 PM
