Hit the limiter in 5th tonight!
#44
#46
What inlet You using?
#48
#50
I am not so mad that i drive over 240kmh with rs turbo in this age, but when i was younger i had ms-efi & t03 rs turbo with 194bhp and it hit easily limiter in 5 gear. Needle was pretty straight down in the speedometer.. : )
#52
Here in Finland if you are caught speeding say 100kmh over limit you have to pay something like 2000-3000Ł fine & you lost your driver license for a 6-12 months easily.
Also you can get 3 months of parole (i dont know if it is right word).
How about that
How about that
#53
here's a pull from tonight from 3500 in third to limiter in 5 total time of 25 seconds and on standard ford ratios on 205 40 17 for those that are interested in that sort of thing on 20psi of boost
#56
Bodger of Blackburn
nah, zvh is alright as it goes, does start to taper off towards 6000rpm, but still plenty of power in it to get it up to top speed, had mine over 150mph once, on the old sat nav, not likely to bother doing that again.
karlos lowered his rev limit to 6900IIRC, no real power over that i think or something like that anyway.
#59
#61
yes need a new intercooler thats why i asked what your on as i'm on a pro alloy one but the max reading was after pull when i coasted and heat soak jumped into the party and car feels stable just everything was moving rather quick glad my brales worked now i'll see what it can pull like when i fit my bottle of gas as i'm planning on using it to help spool turbo then come in again to give a kick after peak torque's gone
#65
showed the pull to someone today and i got the times wrong the total for pull i.e me pulling away to max was 25 seconds the pull from third was 19 seconds i didn't realise what the two times were for so all is getting better all the time and my new intercooler like yours is on its way so when that gets here i'll have mine going surplus great on a mildly tuned rst
#68
Don't forget your ACT's will rocket when you come of the throttle after boost/on the overun no matter what cooler you have so temps were a bit less than that.
SMILER258
28-09-2015 09:04 AM
