Lost spark, and got +12v at both coil terminals!???!!!
Hey up guys, my Turbo'd Bonus has lost its spark? Ive checked for power at the coil with the ignition on and its getting a constant 12v at both coil terminals???!!? So i disconnected the plug on the dizzy, still getting +12v a eah terminal on coil, so removed the green wire off the coil, so thatthere is only the black terminal connected on the coil, and they are still both getting 12v on the coil!!!!!!!!!!??????????? Ive tried a different known to be good coil and its the same???!!! Heeeeeeelllllllpppppppp!!!!!!!
Sounds as if it has no ground and two lives hence why the coil won't work, the green wire will be the earth and the black will be switched live, not sure what ignition system RST has, I am presuming you have a RST transplant? I don't know the RST ignition system but seem to remember they have an inducive module (Which is what the wire on the dizzy would be for) which then sends this signal onto a ESC module. Somehow you have got two lives I should think when ignition is switched off you have nothing? I would check the wiring.
Martin
Martin
07-10-2015 12:56 PM
The Youth.
30-09-2015 09:59 PM
deathrider666
28-09-2015 06:12 PM
