s2 paddle clutch sliping i think
The posh are up!!!
hi when go on high boost i get to 4k rpm and floor it my clutch slips, but if i gradually go up the rev range it doesnt slip, on low boost its fine on all driving styles.
is it time for a new clutch?
The posh are up!!!
running about 18psi on high boost, got helix 4 paddle with std clutch plate, only done about 12k on the clutch, is it hard to change the clutch yourself? so i can save money etc.
What would people recommend for holding about 200 bhp and the same in torque.
Wye Valley Hardcore
When my 4 paddle was on it's way out it juddered very badly in traffic also. Remember to have your flywheel re faced/skimmed before you fit the new clutch as well. You'd be supprised the amount of people who don't.
you have done very well to get 12k on it mate i never used to get more than half that. its time for a new one .
Balls Deep!
Yeah paddle clutches are not designed to last long, there is so little material specialy on the little 3 and 4 puck ones!
An AP Racing CP2000-8 will do perfectly for what you want and will last ages compared to any paddle![](https://passionford.com/forum/images/smilies/smile012.gif)
Easy enough to change, just need to drop the gearbox, little bit fiddly to get back but ok.
Hi Karlos
I was running with 7 psi boost (with standard engine spec) but after up boost to 12 psi (peaks up to 15 psi) my standard clutch is slipping ocassionally on 4 and 5th gear when I put my foot down the floor on accelerator.......
Do you recommend AP Racing Cp2000-8 for a daily car (occasionally fast running on weekends)??
Do you think Standard clutch will slip again after fit a new one?
I want to fit a clutch better that standard one, but I don´t want to fit a "oversized" clutch for my engine specs......
You said pedal feels heavier but how much heaver it feels, a little heavier???
Regards.
Balls Deep!
A standard RST running 12psi will make about 155bhp and similair torque so a standard clutch should be fine, I would say yours is worn out.
Or the AP CP2000-15 would be a good alternative, not as heavy as the 8 or 35 but will take a little more torque than a standard clutch
Or the AP CP2000-15 would be a good alternative, not as heavy as the 8 or 35 but will take a little more torque than a standard clutch![](https://passionford.com/forum/images/smilies/smile012.gif)
So no needed to make mk5 pedal conversion with AP CP2000-15, is it right??
Where can I buy AP CP2000-15 kit online??
I had check on Burtons but I didn´t see it on CVH engines.......
I´ll make search with reference part...............
Many thanks Karlos!!!!!
