F.a.o people using 1.8 rubber rocker gasket
Old 16-02-2010, 05:26 PM
EssexMikeSi
EssexMikeSi's Avatar
Default F.a.o people using 1.8 rubber rocker gasket
Just wondered, did you file dwn the ''teeth'' on your rocker cover so it gets a perfect squash down onto the wider rim of the gasket. People who have one will understand my random explanation of the fiting there lol.
Old 16-02-2010, 06:03 PM
10th_racer
10th_racer's Avatar
never used 1 on a standard rocker cover i only use them with alloy rocker covers, but i know what you mean, i'd imagine you can file down the bits that stick out.
Old 16-02-2010, 08:35 PM
Puss2
Formerly know as Puss
Puss2's Avatar
Its been so long since ive seen under the bonnet of mine i cant remember
Will have a look in a bit
Old 16-02-2010, 09:32 PM
Just bolted mine on, never modded it
Old 16-02-2010, 09:42 PM
Puss2
Puss2's Avatar
I suspect mine will be the same as daves
Old 16-02-2010, 09:44 PM
StephenC
..BS Motorsport..
StephenC's Avatar
just bolted mine down too although Im using a PE rocker cover
Old 16-02-2010, 11:25 PM
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
i'm on a burtonpower alloy rocker cover and just fit it on.
Old 22-02-2010, 08:24 PM
EssexMikeSi
Please excuse the stupid question here, and i admit i havent properly looked at it yet, but what way up does it go? It has a lip on it, does this face upwards or downwards, i noticed there is a 'grove' like line that runs around it so it fits down and over the top rim part of the head, or does it sit over the rim part of the edge of the rocker cover.
Old 22-02-2010, 10:00 PM
Rob_DOHC
Rob_DOHC's Avatar
My groove is rocker cover up, works fine for me lol,
And i just kept the tabs on the cover, doesn't hurt anything. Gasket works a treat well recommended!
Rob,
Old 23-02-2010, 06:48 PM
EssexMikeSi
Cheers Rob,yeah i went out to garage today and had a look and yeah it seems the edge of the rocker cover sits in the groove outline on the rubber gasket. I to had heard they're good plus also heard they dont need replacing everytime u remove the rocker cover unlike cork ones.
Old 23-02-2010, 08:08 PM
Rob_DOHC
Rob_DOHC's Avatar
No worries mate, yea looking at it, won't need to change the gasket when i take the cover off, and if your still on mfi it looks like it will give a better air tight seal.
best of luck
Rob,
liamT74
23-09-2015 10:24 PM
pie-face
15-09-2015 10:43 AM
talon1
15-09-2015 10:27 AM
Chopshop85
12-09-2015 06:42 PM
natehall
Ford Focus (All Models)
08-09-2015 05:13 AM
Quick Reply: F.a.o people using 1.8 rubber rocker gasket
