Electronic Boost Controllers.
Old Feb 8, 2010 | 01:19 PM
conor.rst's Avatar
conor.rst
Default Electronic Boost Controllers.
Yo yo yo.
Just been browsing the site and i seen a few people running Electronic Boost Controllers, they look like a nice handy piece of kit to have.
all tho i did hear it just tricks your car into running more boost than its capable of.
What do you lot think any good or just another pointless mod ?
Old Feb 8, 2010 | 01:44 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
nope very good mod, just about to order a Gizzmo-IBC 3.5 BAR one later this week.
far better than an actuator and bleed valve, you won't suffer surge as much if at all and can program it to have low and high settings, ideal for launches where you lose traction a lot.
it's fairly well priced at £200 or there abouts and hopefully will make it much smoother too
Old Feb 8, 2010 | 05:33 PM
jaiscossie's Avatar
jaiscossie
A very worthwhile mod to do, have a greddy profec in mine.
Old Feb 8, 2010 | 06:18 PM
rstdave's Avatar
rstdave
One of the best things i ever put in mine, got fed up with bleed valves and fluctuating boost! Greddy profec b spec 2 for me, nice and simple and does its job without fail, you can adjust how the boost comes in/spikes etc, mine peaks and just holds boost so well!
Old Feb 8, 2010 | 06:49 PM
orionmojo's Avatar
orionmojo
How much power are you guys above running?
i've not had a problem in almost a year with fluctuating boost etc, or any problems really, i had a -31 actuator and ableed valve fitted, set at 1 bar when the car was setup.
Old Feb 8, 2010 | 07:53 PM
rstdave's Avatar
rstdave
Last engine, 245bhp @1.5bar boost. I'm not saying nothing else works.....but for me personally i had problems delivering and holding boost as i wanted.
Old Feb 8, 2010 | 09:02 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
i love mine, if for no reason that having economy, normal and 'fun' setting at a touch of a button
Apexi AVC-r here
Old Feb 8, 2010 | 09:42 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Amal valve is still a great boost control and if you use the correct size jets inside the pipe outlets you will have a great boost curve. Put your money to better use imo as an amal valve second hand and working is only 20 quids worth. You got loads to do before you thin about boost control issues. Have a read of some technical essays that are on a site which explains how to set them up correctly and make the most out of them.
A bleed valve should never be used!
Old Feb 8, 2010 | 10:17 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
a properly setup bleed valve/actuator combo will work fine, although surge a tad.
mine does surge a bit, but only 2psi at peak.
no amal on mine as i'm using Megasquirt, but I'm definitely going with a Gizzmo, such good press about these and another gauge to add to the list
Old Feb 9, 2010 | 06:35 AM
Chris69's Avatar
Chris69
personally i found a manual boost controller worked well and was much better then a bleed valve i had fitted.
its one of the types with a ball bearing and spring- mine only spikes 1psi or so and comes in alot quicker and harder.
there quite cheap which was my main reason for buying it as i didn't have 200+ to spend on an electronic unit.
Old Feb 9, 2010 | 08:20 AM
Versus_Creations
Ask me a question!
Ok an AMAL valve is an ELECTRONIC BOOST CONTROL VALVE. Why would anyone remove it and FIT A MECHANICAL BOOST CONTROL BLEED VALVE makes no sense.
Its like having an EFi management and removing it to fit MFi
A bleed valve should not be used! what ever fancy colour it is!
Old Feb 9, 2010 | 12:25 PM
sas's Avatar
sas
should be good!
An amal valve is just a mechanical bleed valve. It is opened when the ignition is turned on, it then bleeds of a quanity of air dictated by the size of hole drilled into the restrictor in the vent outlet.
So I feel it a little optimistic to call it an EBC
Old Feb 9, 2010 | 12:31 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
This is what I thought. It's more ELECTRIC than ELECTRONIC!??!
Modern boost controllers use very high quality valves and microprocessor control. The Gizzmo MS-IBC is probably the best there is when it comes to cost vs performance. All the Jap controllers have rocketted in price, where the MS-IBC is still around £200.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
markk
Sep 9, 2015 08:11 AM
