EFi wont run after 15mins
Hi,
Got a small problem, I have a series 1 RST with OFAB EFi, if I start the car from cold it runs fine, a little lumpy on idle but nothing to serious, once it's warmed up and driven for awhile, if I switch it off and wait around 15mins then switch it back on, it runs very lumpy, and wont rev properley, massively over fuels, chucks loads of black smoke on idle. Almost like the timing has been retarded loads
If I leave it for 45mins till its cold again, it starts and runs fine. I have changed the injector loom, injectors, leads, plugs, map sensor, TPS, CPS, idle mixture adjuster, IAT sensor, cleaned out the ISCV, reset the ecu, but still the same problem.
Anyone had anything like this?
Thanks
Thanks
ok will give that a try, seen a cossie management conversion for sale, so might just get that instead of messing about with this system anymore
thanks
thanks
I'm starting to convert mine 2moz, I was at jano oddkidds yesterday, I now have 90% of my parts, another trip to msd i will have 95% so Its spanners out time
Eigdoog
13-09-2015 05:46 AM
