fao morph
Old 04-02-2010, 10:02 PM
  #41
Rob_DOHC
Rob_DOHC's Avatar
But, however shit the launch and every other part of the run, as long as it has grip when it passes the 1/4 mile line, the terminal speed will be condusive to the cars power.
I don't see how this works mate?
The cars terminal speed is effected by every thing including the launch.... i agree to a certain extent that a car doing a high terminal is more powerful, but there have been plenty of cars over the years with far more power than yours and a lower terminal speed up the 1/4......... just gets a bit silly when people start saying that if you don't do 130 over the line you don't have 300 brake!?! what about gearing, the launch etcetc
Rob,
Old 04-02-2010, 10:21 PM
  #42
morph
morph's Avatar
[QUOTE=Tommys1turbo;4701939]
Originally Posted by morph
230bhp low boost and 270 high boost setting
both were wheel spinning as track was icey at first and then greasey later so really no good on shite tyre the yoko s drives as they just didn't warm up once!
stayed on low boost for most of the times as i could not get the power down whatso ever on high boost![/quote
Not wanting to spur on some big hand bag moment hear mate, but i was watching your car go on wednesday and to be fair your car is no way pushing out the power u think it is. the time factors have given it away but i could tell just by watching and listening to ur car that it was nearer 200bhp let alone near 300bhp, whats going on??
what time factors are you going by? the only one i have is what my 0-60 was, and told that my trap speed was 90mph by crazycage and that was on the low boost setting with the timing gear and dan in the car.
the top speed was done on the low boost aswell and that was also with a passenger aswell. If low boost is 200bhp thats all good as i hit 128mph on that setting.
and 8.5 secs to 60mph bearing in mind my gearbox is a s1 which requires 3rd gear to hit 60mph, plus top out at 130mph by it final drive with the wheels i was running + the lack of grip in almost every gear!
Old 04-02-2010, 10:33 PM
  #43
d4 rst
DADDY RST
d4 rst's Avatar
There will be a time when you will show these guys what your car can do you will only get better and better summer is comeing.
Old 04-02-2010, 10:38 PM
  #44
morph
morph's Avatar
new box here we come!
Old 04-02-2010, 10:44 PM
  #45
Tommys1turbo
Tommy Turbo
Tommys1turbo's Avatar
[quote=morph;4702022]
I just cant way up the claimed outputs mate, my s1 has done a 14sec flat with just over 100mph teminal at pod and a 6 sec 0-60 at silverstone, all with just under 220bhp, standard box and road tyres?..
Old 04-02-2010, 11:20 PM
  #46
morph
morph's Avatar
[QUOTE=Tommys1turbo;4702065]
YOUR GOING BY YOUR OWN TIME FACTORS?
How can you compare your car to mine from times taken from different tracks on different days?
santa pod surface is straight and smooth compared to brunters.
what conditions were you in?
was it your first time at trying a 0-60mph?
first time at a timed 1/4mile?
first time at a timed top speed?
my claimed outputs seem way up and you were able to tell that by hearing the car out on track? please can you explain how you worked that one out? i have heard several cars with different outputs and not once was i able to know what power the car was, so please advise what your listening for as i am intreaged?
Old 04-02-2010, 11:51 PM
  #47
Tommys1turbo
Tommy Turbo
[quote=morph;4702119]
look mate, Stu collins found there was more grip yesterday than at the pod the other week and his car was set the same as when he ran at pod? he also did a 13.9 1/4 with the car set all over the place with about 240hp in damp, he had plenty of tyres why didnt u go and borroe a set if traction was such an issue for u.?? so im just waying up your power claims here.
as for ur questions to what my first times were, i have never done under a 15.5 1/4 mile, and they were all different conditions damp, dry, grease burger what ever u like and my 6 sec 0-60 is my first and only one i have ever done properly timed? as for the sound thing mate u dont have to be a rocket boff to no what is quick and what aint, lets all get realistic here.
Old 05-02-2010, 04:37 AM
  #48
T28 RST
Ok then
T28 RST's Avatar
[quote=Tommys1turbo;4701939]
Old 05-02-2010, 10:32 AM
  #49
Ad4m RST
Ad4m RST's Avatar
Rob,
All that being said... if you can't pedal it things get MUCH more variable.
It's obvious whats going to make a bearing in straight line booting. Especially on an Escort.
Old 05-02-2010, 10:43 AM
  #50
Rick
Rick's Avatar
The reason traction doesn't really effect the terminal speed is that on average say the first 60ft takes you 2.5 seconds. That is a massive amount of time for a very short distance. Wheels are spinning and time is ticking, but you're not actually going forward.
When the car grips in say 3rd gear, you are still a very short way down the strip. You are now accelerating and piling on speed - how much depends purely on a combination of power, and power to weight. In reality, the terminal speed over a 1/4 on the sort of cars we run might vary 3mph max regadless of how bad the launch is.
Another way to think about it: At 100mph, you take 0.4 seconds to cover 60ft. So if you had an amazing launch, that gripped instantly and didn't bog down, you would have another 0.4 seconds of accelaration time at the end of your run to increase the terminal speed. A car that does a 13 second quater accelerates at an average rate of 10.7 mph every second - that is after 1 second the speed has gone up by 10.7mph. So if you did a totally impossible launch of 0.4 seconds, you would knock 2.1 seconds of your 1/4m time, but only be 4mph faster on the terminal!
Rick.
Old 05-02-2010, 01:09 PM
  #51
Rob_DOHC
Rob_DOHC's Avatar
point well made basing the sums on linear acceleration like that actually works quite well. I've never really thought about it that much tbh i just turn up and break by car lol
In the real world i think the difference would be greater that 4mph, i vary by at least 0.5 seconds and 3mph across an average pod day and that is with pretty consistent launches, I would say that a terrible terrible launch on a wet day would make a much bigger difference like perhaps 10mph compared with a good dry launch.
Rob,
Old 05-02-2010, 02:40 PM
  #52
morph
morph's Avatar
[QUOTE=Tommys1turbo;4702142]
Borrow tyres at a photoshoot from someone i met the first time? sounds interesting? anyway back to this sound thing, you heard my car from a distance and you worked out it wasn't 300bhp even though i wasn't running 300bhp, so please explain this thing you know?
i still dont know how you worked that out, maybe i should leave dyno sessions and get you to listen to my car to tell me my bhp? LOL
Old 05-02-2010, 02:44 PM
  #53
morph
morph's Avatar
I am still waiting crazecages asnwer as to why he knew my times before i did!
so come on spill the beans, i want to know now why you thought you was clever!
Old 05-02-2010, 03:41 PM
  #54
crazycage
crazycage's Avatar
need to know basis and you dont need to know.
and i dont think im clever !!!!! i am clever clever .
and after all the shit that you have posted in the past few months about your 300hp car i thought it was great that you managed a 92mph trap on your 1/4 .... really shows your power.
nice 16 sec' 1/4s and a great 17sec dash to 0-100 and a very good 0-60 aswell lol .
p-s will be good to see what d4rst manages when his 300hp gets on the black stuf.
Old 05-02-2010, 03:49 PM
  #55
Ad4m RST
Ad4m RST's Avatar
Old 05-02-2010, 03:50 PM
  #56
Tommys1turbo
Tommy Turbo
[quote=morph;4702808]
oh well i new this would turn out to be a hand bag moment, u cant be getting my point here.? U just carry on how u are and relax in your leathered up 270bhp rs turbo, u think what you want and i will do the same. U should have just gone and had some pictures done and made way for some proper power rs turbos to lay some times down!! come back to me when u can show me some times that reflect your cars power cus your no way foookin near mate, END OF MOMENT..
Old 05-02-2010, 03:55 PM
  #57
morph
morph's Avatar
Ok then in that case if you think your smart, Let me make a call and find out why you do know!
  #58
Tommys1turbo
Tommy Turbo
lovin it
Old 05-02-2010, 03:56 PM
  #59
morph
morph's Avatar
[QUOTE=Tommys1turbo;4702962]
you still aint asnwered any of my questions apart from 'lets get realistic? wtf?
come back when you can answer it! so good bye and see ya!
come back to you? what for? if you were that good then maybe your car would have been chosen howver, you know what happend so hard luck and better luck next time LOL!
Old 05-02-2010, 04:05 PM
  #60
Rick
Rick's Avatar
To be fair - good lad for going and abusing your car. I did a thrash once, and got a horrid missfire - downpipe cracked and so afr was reading much leaner than it actually was. Car massivly overfuelled so didn't set any times, things can turn to shit very quickly.
Rick
  #61
crazycage
crazycage's Avatar
make all the phone call's you like .
Old 05-02-2010, 04:19 PM
  #62
morph
morph's Avatar
no worries.
Old 05-02-2010, 04:20 PM
  #63
Micky
Micky's Avatar
Rick
I agree with Rick here,lots of lads go to Brunters and have a bad day,either cars break or no speed/time records get broken.I'd really like to see Morph's times later in the year when he goes back in the better weather,plus the lad is fitting different gear ratios too I think.
I think its better to encourage RST owners to keep improving their cars,so that whatever discipline they enter,be it 0-60,1/4 mile/top speed or like myself,lapping quick at a trackday,their RST gets faster. Micky
  #64
morph
morph's Avatar
Rick
cheers
Old 05-02-2010, 04:23 PM
  #65
morph
morph's Avatar
Spot on mate! too many haters on these forums.
Old 05-02-2010, 04:24 PM
  #66
crazycage
crazycage's Avatar
more like to many bull shitters but fair play for having a go really sorts the men from the boys so to speak.
Old 05-02-2010, 04:25 PM
  #67
morph
morph's Avatar
See what i mean!
HATER!!!!!!
Old 05-02-2010, 04:27 PM
  #68
crazycage
crazycage's Avatar
See what i mean!
HATER!!!!!!
hate you !!! i dont know you .. you made your phone calls lol.
Old 05-02-2010, 04:37 PM
  #69
morph
morph's Avatar
Haters United!
Old 05-02-2010, 04:43 PM
  #70
Tommys1turbo
Tommy Turbo
[quote=morph;4702976]
The only reason yours was there was because you were saying how fast and how much power you had, so i guess they wanted to see it and what it could do??????...... Now we all no its a load of Booolarks and you have got a slow 200bhp car if that? no direspect to cars with 200hp by the way!! So looks like you wont be getting an invite again unless you get a big boy power figure and lay some proper times down. But Like i said its all just talk the talk on here as usual..... your a legend mate!!!
Old 05-02-2010, 08:04 PM
  #71
d4 rst
DADDY RST
d4 rst's Avatar
Come on then guys what was your times like 1st time out and was it wet.
Old 05-02-2010, 08:22 PM
  #72
morph
morph's Avatar
[QUOTE=Tommys1turbo;4703126]
Handbags!!!!! you really know how to do that bit well!
the only reason mine was there was becuase the guy who should have been there did not make the figures and withdrew! was that you? sounds like it!
Old 05-02-2010, 08:51 PM
  #74
jammerrs
jammerrs's Avatar
Originally Posted by S1 JOHN S1
WTF.....,
Arn't we all on here to help one another not bitch about each other?
i thought so.........obviously we were wrong
id like to see what your car can do on a good day pal, and as said i think its all about encouraging people to stick to these cars and show what they have done to them
Old 05-02-2010, 09:04 PM
  #75
morph
morph's Avatar
some peeps on here don't like to help they like to take the piss!
any way if my cars not 230bhp i am happily excepting 200bhp for now!
thanks for th postive comments from people on here
Old 05-02-2010, 09:09 PM
  #76
Ad4m RST
Ad4m RST's Avatar
Good day bad day, fair enough. But if you set yourself up for one the fall is harder...
Old 05-02-2010, 09:23 PM
  #77
DanW@FastFord
Spelling Club King!
DanW@FastFord's Avatar
Not going to comment on the cars power figures, but traction when Morph was running was pretty much non existant, and as I went in the car with him for one run I can confirm that the power delivery is very very harsh when it comes on boost and anyone would have struggled with the combination of the car and the conditions.
I'm sure Morph won't mind me saying that he was nervous about running and was very honest about his limitations when it came to launching the car.
Old 05-02-2010, 09:30 PM
  #78
DanW@FastFord
Spelling Club King!
who do you think put the timing gear on your car lol.
Me. Not quite sure what you mean by that rather odd post.
Old 05-02-2010, 09:31 PM
  #79
morph
morph's Avatar
Cheers! appreciate your comments.
Old 05-02-2010, 09:35 PM
  #80
Lloyd
escort mk4 cossy 4x4
Lloyd's Avatar
iam a bit shocked to find it was ff event..fwd at the beginning of feb..you should know better with neil being a fwd specialist.
where was the invites to the big power fwd cars? or was this a different kind of feature?
Quick Reply: fao morph
