Boost
Hi guys. Wen I put my foot to the floor my max boost is 15 psi but then it drops off quickly to around 10 psi mark is this normal or is the actuator on it's way out.
Cheers joe
Cheers joe
I have a new acuator so will fit that and see. Just bit worried about changing it should I just measure the rod and masure it's the same.
Cheers joe
Cheers joe
first thought is actuator, i've just replaced my spring in my collins one due to the same problem, it's mint now and holding much more boost, without a bleed valve i could only get 7psi max, now on the actuator alone i'm getting 14psi, open bleed valve half a turn and hitting 16, one and a half turns and it's about 21psi, which is the limit for my ecu's map sensor.
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
