Escort RS turbo tunning - help please
Hey everybody!
I own a spec 90 ford escort rs turbo and I want to tune it to achieve about 300 bhp. I'v already started to get some equipment but I still have a few doubts about the correct material to acquire and tune.
My base is the RS turbo converted to EFI management (OFAB) and:
- Accralite forged pistons (1,5 mm oversized, comp. ratio about 7,8:1);
- Con rods THS UK-Performance;
- GRS-Motorsport intercooler (large front model);
- Stage III head (Burton Power);
- Lightweighted and balanced crankshaft ando flywheel.
What do I need to acheive the pretended bhp (material and tunning[chip, mapping...etc]) with reliability, so I don't go 5k miles and get trip assistance
In my idea, this is the missing equipment I thought it would be enough but...I need to be certain about it so I dont spend all my cash wrongly:
- High pressure oil pump (Burton Power);
- ACL Bearings (big end and main);
- Kent cam double valve spring set;
- Newman camshaft sprint CVH turbo 1600 phase IV and solid lifters;
- Hybrid turbo exchange, 2wd cosworth YB (Burton Power) - stage II;
- Bosch fuel injectors 803 green;
- Power boost valve FSE;
- Cometic multi-shim head gasket;
- AP ARacing clutch kit CVH/Zetec 220mm four(cross) paddle;
- Bailey swirl pot;
- Bailey oil separator tank;
- Bailey header tank;
- Mongoos stainless steel exhaust system
...and...
- Forge Motorsport actuator (20-28 PSI enough???)
- Fuel pump (what model and where to buy???)
- My ECU suports anti-lag?
- what's the correct pressure for my comp. ratio and equipment?
- gearbox: can it handle?(1.6d fiesta gearbox with an 3.33 final drive)
Basicly: is this enough/correct? what else do I need? are there any special attention in all this material assembly?
Opinions/comments/ideas please...
regards
- Bailey swirl pot;
...and...
regards
Balls Deep!
From what i know.... loose the OFAB as it's not easily mappable and you cant get an off the shelf chip for what you want to do!
Also none of the bailey stuff is needed except maybe the breather setup, nor is the Cometic gasket, the Power boost valve FSE, and you probably dont need double valve springs either.
hey, sorry i didn't understan the part you said: "loose the OFAB as it's not easily mappable and you cant get an off the shelf chip for what you want to do!"
can I get those bhp with my OFAB or what should I get to i
Hey everybody!
- Stage III head (Burton Power) (wouldn't give Burton any money, overpriced and their so called technical guy doesn't have a clue);
- High pressure oil pump (Burton Power); (arguably needed)
- Kent cam double valve spring set; (Use the Newman items)
- Power boost valve FSE; (Throw in skip)
- Cometic multi-shim head gasket; (standard Ford will suffice)
- Bailey swirl pot; (not required the thermostat housing has one built in)
...and...
- gearbox: can it handle?(1.6d fiesta gearbox with an 3.33 final drive) (no chance, will need a specially rebuilt box and a LSD or ATB differential)
regards
...and...
regards
Hey! My idea was to use my OFAB and a custom chip made there in UK(motorsport developments, i would sent my spec's to there so they could map a chip) but my doubt is that if it is possible to do it without my car there (weather conditions...air...humidity...etc)...
regards
Hey!
About the head, what would you advise me to get?and where xD?
What's the correct pressure for my comp. ratio and equipment? can you give me a clue or a reference value?
regards
regards
regards
Matt Baxter
16-09-2015 08:30 PM
muz
16-08-2015 12:57 PM
