Exhaust question,
Guest
Posts: n/a
Exhaust question,
My exhaust at the olive down pipe (where it connect's to the underside of the turbo) is blowing out towards the alternator,Now tried fitting spring clamp's so when it got warm it may bend back to shape,But it's still blowing not as bad as it was but still losing pressure,
So 15PSI of boost and i must be losing 5PSI through the blow lol
Any idea's on how to fix it? See a custom exhaust manufacturer and have a new olive made up and fit and weld that to my exhaust?
Any idea's would be helpful
CheeRS
CheeRS
its usually the rest of the exhaust system incorrectly fitted,and it pulls the joint apart. loosen all the clamps and joints and try to release the pressure on the manifold joint.unless its damaged? damage can normally be straightened out with some heat and a ball pin hammer
Guest
Posts: n/a
As my back box to where the hole (semi circle) is on the rear.The back box is dragged slightly to right making it not a perfect fit (Ish)
CheeRS llyod will give that a go
wheelwizardrefurbs
21-09-2015 06:42 AM
