metal clutch quadrant
Old 17-01-2010, 10:27 AM
Matthew_M
Matthew_M's Avatar
Default metal clutch quadrant
seen these few years back anybody know where to get them?
Old 17-01-2010, 12:13 PM
Twiddle
South lincs rsoc
Twiddle's Avatar
Yeah i had one but going hydrolic so sold it, was not from ebay but some one like Zoo motorsport or MEF, really can't remember now, not much help am i?
Old 17-01-2010, 12:58 PM
Jimmyc
Jimmyc's Avatar
A lad on here has one for sale in the for sale section bud
Old 17-01-2010, 02:03 PM
dave_y
dave_y's Avatar
Old 18-01-2010, 03:16 PM
S1 Combi
S1 Combi's Avatar
When you fit these is it just a case of adjusting the pedal manually as apose to the ratchet system of the standard one?
Old 18-01-2010, 03:18 PM
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
that's exactly how it is.
Old 26-07-2010, 12:07 PM
JUS018
JUS018's Avatar
Default Escort mk6 metal clutch quadrant.
Hi, i need a metal clutch quadrant for my escort mk6 van, from where can i get one pls? The pressure plate is a Helix one, the original plastic quadrant broke two times already on it. Any help pls? Thanks, justin. Pls email me on justin.grech@gov.mt
Old 26-07-2010, 12:09 PM
JUS018
JUS018's Avatar
[quote=JUS018;5016336]Hi, i need a metal clutch quadrant for my escort mk6 van, from where can i get one pls? The pressure plate is a Helix one, the original plastic quadrant broke two times already on it. Any help pls? Thanks, justin. Pls email me on justin.grech@gov.mt
Old 26-07-2010, 07:03 PM
nigel b
nigel b's Avatar
[quote=JUS018;5016338]
http://www.extremesportsproducts.com...d&productId=17
it says they are out of stock
ill find out tommorow
Old 29-12-2014, 05:29 PM
luxembourgrst
luxembourgrst's Avatar
do we can still find them?
Old 29-12-2014, 05:42 PM
grcossie
grcossie's Avatar
http://randbmotorsport.co.uk/shop/De...?ProductID=386
Old 29-12-2014, 08:53 PM
luxembourgrst
120 pound ???so expensive
well I built my ib5 gearbox with rst lsd and flat relase bearing in and with ap 2000-8 organic clutch
i started to built in the white quarand 10 teeth cut and the mk5 pedal
but i don t like it to mutch play a stretching when pushing the pedal
with the ap 2000-8 maybe the standard mk4 pedal can be use
Old 07-01-2015, 06:42 PM
Cameron
Cameron's Avatar
you could just make your own, i had my old man knock me one up from a block of steel, cut the mk6 quadrant down and pretty much copied the shape of it and drilled some holes in it to make it lighter, been running it for a year now and no problems whatsoever
Old 07-01-2015, 07:27 PM
luxembourgrst
yeah looks fine I putted the standard mk4 pedal with automatic adjust quadrant the pedal is a little bit hard to puch but looks fine but how long
Old 15-01-2015, 09:39 AM
Christian and Beccy
#1 in Spelling Club
Christian and Beccy's Avatar
I always ran the plastic quadrant on mine and never caused an issue with any clutch I ever used.
Old 18-01-2015, 09:58 AM
luxembourgrst
the standard mk4 quadrant or the with one with cut it back?
Old 20-01-2015, 02:20 PM
Christian and Beccy
#1 in Spelling Club
Was an original quadrant, modified according to AP Racing guidelines.
Old 06-02-2015, 12:54 PM
luxembourgrst
well I tried with the original mk4 quadrant with automatic adjust and the pedal is very hard an the clutch way is to short when im holding the pedal on the floor an let it 1mm up is directly clutching the way is to short and the 1 gear don t go in very well
well I try with the mk5 quadrant like the ap racing clutch sayed
but need to drill a hole to take the spring an hold the pedal down
Old 08-02-2015, 05:51 AM
Versus_Creations
Ask me a question!
Versus_Creations's Avatar
Drill the pedal and weld a nut to it. Then use a head bolt with another nut on it to lock it in the correct place. Replicated mk5 without the need to remove the pedal.
if its broken then obviously no choice but to remove it.
In all the years I have been building, racing cars I have mot needed a metal jazzy quadrant.
Old 09-02-2015, 07:50 PM
luxembourgrst
well I already have a mk5 pedal
but d on t know why but I d on t need to cut the quadrant 10 teeth off because with the cut off my bolt was on maximom to have clutch relase
maybe because the car is a left drive and the clutch cable to long
well I just bought a new mk5 quadrant big radius an try witouht cutting it off
Old 09-02-2015, 07:52 PM
luxembourgrst
i also think without cutting it off there is no more chance that the quadrant break
Old 24-03-2017, 09:00 AM
polle90
polle90's Avatar
Is this alloy clutch quadrant still for sale somewhere? I am looking
for one for my mk4 cabrio turbo.
Old 25-03-2017, 08:28 AM
pectelboy
pectelboy's Avatar
Anembo engineering do them , he's sold a fair few of the alloy ones
Old 30-03-2017, 09:52 AM
polle90
polle90's Avatar
Thanks, not cheap. When I use the mk5 pedal and quadrant do I have
to put the spring back on? Is it the spring from an MK4 or MK5 clutch pedal?
Old 26-07-2017, 11:28 AM
Karlos G
Balls Deep!
Karlos G's Avatar
MK4 Spring.
Yes to ensure the pedal doesn't flap around, you fit it to hold the pedal down and take up play.
Old 04-08-2017, 08:11 AM
zvh
zvh's Avatar
http://extremesportsproducts.com/ind...d&productId=17
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
arkeye
Ford Focus ST
20-02-2016 01:22 PM
jameswrx
Modellers Corner.
17
09-10-2015 08:26 PM
Quick Reply: metal clutch quadrant
