S2 Problem
Old Jan 8, 2010 | 07:23 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Alternator wont effect the spark until the battery is flat, but it cant be good and would explain why the battery is not charging?!
Sounds to me like the green wire that runs from the coil -VE round the FRONT of the engine bay into the loom near the ECU has snapped, this triggers the coil from the ECU based on a signal from the dizzy.
If it's broken there will be no spark
Old Jan 9, 2010 | 06:50 AM
JesseT's Avatar
JesseT
Definately sounds like a problem in the loom.
Also, I hope you are really sure it's the ignition that is at fault and not for example the fuel pump safety circuitry.
Old Jan 10, 2010 | 06:27 PM
RSmark84's Avatar
RSmark84
to rule out another fault i'd get the Hall Sensor checked, just a voltmeter readed on it will tell if its working and not breaking down.
If this is faulty it will cause the car many problems like you mentioned. once the hall sensor fully goes the car wont start at all.......
Old Jan 10, 2010 | 06:54 PM
SteveXR2T's Avatar
SteveXR2T
!! Give me a break !!
if mfi then check the plug on the dizzy always f"cking up
Old Jan 10, 2010 | 07:13 PM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
Had exactly the same problem with mine turned out the green wire from the coil had snapped under my intercooler where it runs along the crossmember!!!
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
