Well.......CAUSE FOUND!!!!
Old 02-10-2009, 08:49 PM
  #41
LEE-RS
Custom
LEE-RS's Avatar
he means the clearance between valve and rocker arm when you adjusted your lifters
if these are slightly too tight the valve wont seat properly and become very hot
Old 02-10-2009, 08:52 PM
  #42
Karlos G
Balls Deep!
Karlos G's Avatar
Oh I see, the clearance was whatever Newmans specified cant remember off the top of my head.
Old 03-10-2009, 02:14 PM
  #43
Karlos G
Balls Deep!
Karlos G's Avatar
Found 90% of the seat in the inlet manifold branch!
Old 03-10-2009, 04:50 PM
  #44
Rob_DOHC
Rob_DOHC's Avatar
SHIT
I would strip the engine now that you've found that buddy!
Looking at your bore i think if it were mine i would re-bore... as i don't think a honing tool will remove the majority of the damage...
Rob,
Old 03-10-2009, 04:53 PM
  #45
Karlos G
Balls Deep!
Karlos G's Avatar
Been given a new bottom end, cos the bore has nasty scrape marks further down that I hadnt noticed yesterday.
Rebuild time!
Just hoping some good will happen with my head!
Old 03-10-2009, 04:55 PM
  #46
Rob_DOHC
Rob_DOHC's Avatar
sorry mate i edited just as you posted lol but good news on being given a new bottom end!
Thought about zetec bottom end at all?
rob,
Old 03-10-2009, 04:58 PM
  #47
Karlos G
Balls Deep!
Karlos G's Avatar
Nope IMO ZVH is a big waste of time unless you have the money to have a big valve stage 3 head, a big turbo, and a good gearbox to take the extra torque! lol
For the price (if done properly) may as well go full Zetec turbo, just my opinion of course!
Old 03-10-2009, 05:02 PM
  #48
Rob_DOHC
Rob_DOHC's Avatar
I dunno i kind of like the idea of running really low boost and still getting over 200 brake (as in 8-10psi),,, just for reliability etc.
Old 03-10-2009, 05:04 PM
  #49
Karlos G
Balls Deep!
Karlos G's Avatar
It's not any more reliable, how often does your bottom end fail?? Still running the same Head, fuelling, and ignition system
Old 03-10-2009, 05:05 PM
  #50
Rob_DOHC
Rob_DOHC's Avatar
not a bad point!
Old 03-10-2009, 05:07 PM
  #51
Karlos G
Balls Deep!
Karlos G's Avatar
It's everything other than the bottom end that makes RST's unreliable! lol
Bottom end is good for around 250bhp if looked after!
Old 03-10-2009, 06:18 PM
  #52
dan-dan
dan-dan's Avatar
What does it mean if your manifold is glowin? my esrt running 18psi of boost i can get the manifold to glow after a trash. is it safe, it dont matter now its being rebuild but not because of this
Old 03-10-2009, 08:04 PM
  #53
Received 1,044 Likes on 998 Posts
What a mess.Im glad its sorted now.
Old 03-10-2009, 08:26 PM
  #54
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
could be underfuelling or too much timing advance.
or just normal, i'v ehad them glow a few times, and to be honest i've had good and bad setups and all have done it at some point.
too small a tubo housing can cause this by not flowing gases fast enough.
good news on the bottom end Karlos, well sort of, zvh would be a good intermediate step, but would cost a bit more than cvh. full zetec is where it is for the most potential, but alas even more cost than either of the other options.
Old 03-10-2009, 08:39 PM
  #55
GaryEvo
GaryEvo's Avatar
also them numbers in map mean nothing unless you had checked base timing vs timing on ecu live data
Old 03-10-2009, 08:48 PM
  #56
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
what do you mean by that?
those numbers represent the ignition timing set by ecu for given rpm and air pressure, there is no base setting for timing, it's all read from the table.
Old 03-10-2009, 08:53 PM
  #57
Christian and Beccy
#1 in Spelling Club
Christian and Beccy's Avatar
Part of the initial calibration of an ECU is to make sure that the timing value in the live data is the same as the actual amount measured at the engine. Hence if you share timing maps, you need to be sure that you have the sorted and that the person you got the map from had that sorted too.
Old 03-10-2009, 09:23 PM
  #58
Karlos G
Balls Deep!
Karlos G's Avatar
Dont see you on here very often Gary! Cheers for your input!
But the base timing was checked with a light at idle so the values in the map are indeed correct
Old 03-10-2009, 10:32 PM
  #59
GaryEvo
GaryEvo's Avatar
cool,well done then i shall keep my epic fail badge for the next guy!!
Old 04-10-2009, 12:22 AM
  #60
DazC
DazC's Avatar
valve clearances are not the cause of the seat failure.
Old 04-10-2009, 12:26 AM
  #61
Karlos G
Balls Deep!
Karlos G's Avatar
I think you may be able to save it for NMS on this occasion, i've taken the head to two engineering companies this afternoon and I guy I know that has a lot of experience with Cossie heads and they all think that too much material being removed from behind where the seat sits has caused the failure, the impact of the valve seating has gradually knocked the seat through what material there was behind the seat until it dislodged.
Old 04-10-2009, 10:08 AM
  #62
Karlos G
Balls Deep!
Karlos G's Avatar
Well diagnosed at least, sorted............. give me a couple of weeks she'll be running again!
Yeah is good new Sean!
High EGT's are caused by too much timing retard, Det is caused by too much advance.
As I said above not really a fan of ZVH's but just my opinion.
Plan so far.............
Strip this new bottom end wednesday, meassure and inspect the crank journals, order up some shells, and get it reground if needed.
New rings, a honing tool, head bolts, and full Payen gasket set are already on there way, just need a EFI flywheel now! Ditching the trigger wheel setup as I can just drill the block as it's out and fit a CPS to that, much tidier!
Old 04-10-2009, 11:04 AM
  #63
clarke5700
YES I KNOW I CANT SPELL
clarke5700's Avatar
good news mate make sure you take loads of pics as you go along lol. where did you get your 5th gear puller btw? im gonna take this box apart to conferm what it is lol
Old 04-10-2009, 11:09 AM
  #64
Karlos G
Balls Deep!
Karlos G's Avatar
Well i got a 3 legged puller from ebay and that did the trick after a bit of heat.
http://cgi.ebay.co.uk/Reversible-Pul...d=p3286.c0.m14
Old 04-10-2009, 11:24 AM
  #65
clarke5700
clarke5700's Avatar
mint thanks
Old 04-10-2009, 03:50 PM
  #66
LEE-RS
Custom
LEE-RS's Avatar
in your inlet manifold runner , how they get there is there any damage to the inlet valve seat as when they went past ?
Old 04-10-2009, 03:55 PM
  #67
GaryEvo
GaryEvo's Avatar
you could always buy christians engine mate!!
Old 04-10-2009, 03:56 PM
  #68
Karlos G
Balls Deep!
Karlos G's Avatar
Mate there is damage to everything!! LOL!
Fuck knows how that got in there, inlet valve is only open on the intake stroke?!
  #69
Christian and Beccy
#1 in Spelling Club
Been there, done that one!!
Old 04-10-2009, 03:58 PM
  #70
clarke5700
clarke5700's Avatar
lol
Old 04-10-2009, 03:59 PM
  #71
Karlos G
Balls Deep!
Karlos G's Avatar
Yeah see my Sig!
Old 04-10-2009, 04:09 PM
  #72
LEE-RS
Custom
LEE-RS's Avatar
yes karlos buy christians engine, you can carry on where he finished do you think your escort cab could take 180 mph
Old 04-10-2009, 04:10 PM
  #73
clarke5700
clarke5700's Avatar
do you think his box would take over 300bhp
Old 04-10-2009, 04:33 PM
  #74
Christian and Beccy
#1 in Spelling Club
I lobbed £500 off the price too. The plan is to remove the head and check it more thoroughly too, before its sold. So, it'll have a new head gasket.
Old 04-10-2009, 04:40 PM
  #75
jonny s2
jonny s2's Avatar
you know that engines properly sorted,get it bought
Old 04-10-2009, 04:53 PM
  #76
Karlos G
Balls Deep!
Karlos G's Avatar
LOL No!!
PMSL!! No!!
LMAO Would love to!
Old 06-10-2009, 07:26 AM
  #77
Karlos G
Balls Deep!
Karlos G's Avatar
Latest response from NMS..........
Hello Karl,
Oli has been dealing with your correspondence until now, and has brought me (Karl) up to speed with your problems.
I’m still waiting on seeing the head myself, but in reply to your last statement regarding the land beneath the seat, this is in fact what all cvh heads are like once they are ported. (And I have ported literally hundreds of CVH heads). If you look at a cvh head as standard the lowest portion of the exhaust port is at the same depth as the seat insert, and thus it is impossible to have full material beneath the valve seat on the short side turn. (This is because the insert depth is level with the port base and hence to get a smooth turn into the exhaust port requires the land behind the seat to be removed.) If you inspect a std CVH head you will see it has a very sharp ridge there to give a small amount of extra land behind the seat.
This however has never been of any issue with regards to seats falling out. The only issue it can cause is mild valve seat recession, which on heads where this does occur, we resolve by the fitting of oversize seats giving more land for the insert to sit on. This still leaves little land on the short side turn simply due to how low the exhaust port is. It is in any case the material around the circumference of the seat that holds the insert in, NOT the land behind it. Seats are fitted with around 4 thou interference, by both heating the head and shrinking the insert. The cause of inserts falling out is always excessive heat, although it has never happened on a CVH before, so this is a first!!
My recommendation based on the photos (which I will confirm once I have seen the head in person) is that we fit eight oversize seat inserts with maximum interference fit, which will ensure the seats are as tight as possible and the chamber can easily be repaired. I will speak to you again once I have inspected the head.
Best regards,
Karl
My reply........
Thanks for the explanation Karl, the courier is booked for collection tomorrow so the head should be with you Wednesday or Thursday at the latest!
If the head can be repaired then that is great, I assumed with that sort of damage it would be written off?!
Just something else to note and may be of relevance to this situation, when the Newmans cam and Solids were fitted there was not enough adjustment in the lifters to create any clearance at all between the lifter and rocker arm because of how recessed the valves are in the head, to overcome this David (Newman) suggested he send me out lifter adjuster bolts that have been skimmed to give the needed clearance and said this had only happened before on heads that had extensive valve work.
I don’t know if this relevant but thought it worth mentioning?!
Thanks,
Karl.
So just waiting now to see what happens when they get the head and inspect it in the flesh!
Old 06-10-2009, 09:48 AM
  #78
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
at least they have a possible solution to the problem and are confident.
Old 06-10-2009, 12:17 PM
  #79
Rob_DOHC
Rob_DOHC's Avatar
indeed, at least they are not saying... fuck off, not my problem all your fault etc.
However Karl does seem to have taken the stance that it is not his fault..... i actually disagree with some things he has said, but maybe see what his reply says...
Rob,
Old 06-10-2009, 12:22 PM
  #80
Karlos G
Balls Deep!
Karlos G's Avatar
Head should be with them tomorrow so we'll soon see, hopefully they will sort it out so I have at least not lost the £644 I spent with them on the head!
Latest email:
In reply to the comments regarding valve seat height, (you quote “ because of how recessed the valves are in the head”) although the seats have been recut in your head, the valve heights are very similar to standard as I check this on every head I do, to ensure they are within usable tolerance. Obviously these heads are getting very old now and thus have often had the seats cut before hand, but your head was checked by myself and found to be within good tolerance. With regards to the solid follower problem, this is in fact an issue with Newman cams NOT your head as we have also had this problem with all their latest solid followers. This problem was brought about due to Newman increasing both the thickness of the top screw head, and increasing the thickness of the lock washers, whilst the follower body has remained the same length. (12 months ago their followers were different to this). This means that they have increased the minimum fully closed length of the follower, but they have not reduced the cam base circle to increase the adjustment range, and thus we too have had this same issue. We have fixed this problem by using a thinner lock nut to give the extra clearance, but the correct fix should either be a shorter follower body or a smaller cam base circle.
I’ll await your head later this week for inspection.
Best regards,
Karl
Quick Reply: Well.......CAUSE FOUND!!!!
