fuel pressure
fuel pressure
on a zvh cossie managed rs turbo with about 270 bhp what fuel pressure should it be,and how do you check it please,also which way does the petrol flow.
cheers
cheers
You need to attach a gauge before the fuel pressure regulator, ie at the end of the fuel rail.
Im not sure if it should be same as a cosworth but cosworth fuel pressure should be 3.5 Bar
It should flow from the pump into the fuel rail then into the fuel pressure reg then back to the tank.
Is it aeroquip or is it just rubber fuel hose? If its aeroquip you can get a t piece that screws into the -6 fittings and then attach the gauge here.
If it is rubber, take the hose off the end of the fuel rail and get a t piece and join it in with another peice of rubber hose.
Or if you can with your pressure regulator depending on which type you have you can attach the gauge directly into a blanking plug on the regulator itself if it is easy to get too and see.
SMILER258
28-09-2015 09:04 AM
