Metering Unit Rebuild Kit - Still Available?
#41
If the is hot it just wont start period, pulled off a3 today and stalled the car in rush hour... wasn't fun.
The mixture is deff wrong lol but fixing it/identifying the problem is going to be a pain.
Any one know of any companys who refurb the units?
Rob,
Rob,
#42
Balls Deep!
Mate did you not read my last post? lol It is probably not the metering unit!!!
Why dont you just try leaning/richening the idle mixture and seeing if it makes it any better?
Refurbing/replacing the metering unit is the most expensive route to go and then you would still have to set the idle mixture anyway! lol
#43
My bad Karlos! Sorry i was tired...
I agree, and will give that a go this evening lol Just got a quote for a refurb unit at Ł440
Should i be able to strongly smell fuel if i open the metering unit? with engine and pump off?
Also should a perfect RST start on the button with no throttle?
(last one) any one know of a good firm who could set up my car around SE London?
Cheers again
Rob,
Cheers again
Rob,
#44
Think these links may be useful to people.... especially the PDF as it has a fault finding table...
http://www.covin.co.uk/tech_2.htm
http://www.fastfordmag.co.uk/resourc...AF268.tech.pdf
http://www.fastfordmag.co.uk/resourc...AF269.tech.pdf
http://www.siipicossu.com/manuaaleja/ERST.pdf
http://www.scribd.com/doc/18010597/e...Fuel-Injection
They are all really useful!
Happy reading
Rob,
Happy reading
Rob,
#45
Here's some pictures of mine its been striped down polished and fully clean from inside then rebuilt with some new parts including gasket and banjo bolts thought I’ve keep it as a back up just in case mine starts playing up in the near future.
#46
meter unit gasket
hi i have just started stripping my s2 and have brought a lot of new ford parts from ywk.com and they will have gaskets in at the end of september. good place to tryfor any bits you want.
155lee
24-10-2015 11:11 AM
