erst turbo leak
erst turbo leak
seem to have a leak from the turbo theres only seems to be two top bolds holding the turbo in place two are missing are they m10 bolds i need for the bottom two thanks
are you talking where the turbo goes onto manifold if so it studs and nuts and locking washers they sell the hole kit on ebay for about a tenner you get 4 studs/nuts and gasket
but you better make sure there not snapped in the maniflod try poking somethink through the holes
mark2
hi
check to see if there in there snapped if not get some studs and nuts as mentioned above and dont drive it leaking
you will have to separate the turbo from manifold to put the new studs in as they are to long todo whilst attached
if on the other hand they are snapped in there it might be easier to get another manifold unless you have a stud extractor kit and blow torch and a few hours
mark
mark
JK12
33
26-04-2021 12:09 PM
Matt Baxter
16-09-2015 08:30 PM
