s2 mongoose exhaust install
Hi
i have a new mongoose exhaust system to install on my s2, but the sytem came whith a mount seperatly, can somebody tell me here is the rigth plate for this part? if you can, please post pics of underside s2 whit this system.
best regards
best regards
thank you for the quick reply, i dont now if is this mount, please can you check this pic on next link?
http://www.powerconversions.co.uk/images/rsts1s2evo.jpg
im talking about mount, on the right of back box ( in picture)
regards
regards
hi
Today i put the exhaust on the car.I use the mount on "STEVENEBM" picture, to fit the mongoose sistem, but i dont know if this is the rigth fit....
When i look the car underside, i think the exahust ( donwpipe at midlle of the car) look too low, and dont have any mount on this part of the exhaust, its not danger on aceleration?
maybe put the standard exhaust again.....
post whore
hi
maybe put the standard exhaust again.....![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
there isnt any middle section mount and the exhaust does hang down a bit.i have a mongoose on mines.think there is three mounting points.one for backbox.one in the picture and another next to like the passenger side rear chassis leg if i remember correctly.
hi
yes mate, its only 3 mount, when i see the standard exhaust have more 1 mount, on the standard flex.
Mate dont you have any problem whith the exhaust? on hard drive for example, and whith the move of engine? I ask this because, i think the exhaust dont have " flexibili"...
sorry for my english lol
reagrds
reagrds
post whore
never had a problem before with mongoose as they havent got the flexi section.if your really worried you could go to a local garage and get them to install a flexi.not ideal as its a new exhaust but you should be ok as im sure loads on here are running them without flexi section mate.
slacken the nuts on the front pipe/turbo. Then loosen the clamp off and the clamp on the rear box.
Put a trolley jack under it and lift it up slightly, then tighten all the nuts and clamps back up and it should be fine.
Mine sagged a bit and after this i had no problems.
