Wanna turn up my boost
Hey guys was thinking of turning the boost up on my rs turbo, But i cant remember which way i turn the actuator???
Thanks alot
Thanks alot
Are you on the lookout for a new engine?
Turning up the boost is a major engine killer without it being setup to cope with the extra boost as your fueling will be out
It Wasnt Me!
best thing to do mate! its not worth the price of a rebuild.
and for the record, more tension = more boost!
best way to do it, is set the actuator to be just tensioned so the hole sits half over the wastegate dowel thingy, then run a bleed valve.
Yea your right mate just being experimentif wanna learn all a can. How much psi can my standerd actuator cope with???
rsguy
44
29-09-2015 03:29 PM
Russ Payne
25-09-2015 08:29 PM
