Focus RS brakes.....
Was thinkin about using focus rs setup, i've seen a few with this setup, was wondering exactly what's involved to fit them?? I.e are brackets available/made by anyone, spacers etc?? Also anyone running the setup, your opinion on what the setup's like?!
Cheers,
Dave.
Cheers,
Dave.
Thanks for the replies guys, still none the wiser as to the availability of brackets to mount them, sounds like it's a custom job then? How does the standard master cylinder fare with the rs brakes, are you running anything different?? Oh and i've got 17's but is it likely that they won't fit under all 17's, i've got oz superleggera's.
You will need
FOCUS RS BREMBOS,
FOCUS RS DISCS
FOCUS RS PADS
CUSTOM BRACKETS(ZOO MOTORSPORT FOR Ł70)
EXTRA LONG BRAIDED HOSE
WHEEL SPACERS FOR 17,S unless you have got COMPOMOTIVES.
Here,s some pics of mine.
Had to use HUBCENTRIC SPACERS on mine to fit the wheels.
All in,your looking at around Ł350-Ł400 to do this conversion.
FOCUS RS BREMBOS,
FOCUS RS DISCS
FOCUS RS PADS
looks a good set that ,cant beat a nice set of brembo's
but if on a budet mrk3 mondeo calipers and brackets ,rs focus caliper bolts with washers st170 disc and mrk3 mondy pads fit a treat under 16" or 17" reconmend this set to anyone think my m8 is planning to run this set up on is 1988 xr3i/turbo escort
wowk
30-03-2021 08:49 PM
